Do you prime your oil filter?
Old Feb 11, 2013 | 02:35 PM
Jeff_Keryk's Avatar
Jeff_Keryk
Default Do you prime your oil filter?
Another oil thread!
I always do, because I don't like the few second zero oil pressure start.
Unfortunately, not all engines are as well designed as our bazillion year old Chevys!
I hate those horizontally mounted filters; at least they are usually pretty small.
Old Feb 11, 2013 | 02:52 PM
MrJlr's Avatar
MrJlr
ALWAYS!
Old Feb 11, 2013 | 03:25 PM
SOMFormula's Avatar
SOMFormula
Always do, here!
Even if they are Horz mounted...I just roll the oil around in them for a while before I install them.
Old Feb 11, 2013 | 03:43 PM
Crepitus's Avatar
Crepitus
defanatly! I set the new filter out and pour oil in. pour the rest of the quart into the engin. next quart top off the filter, pour the rest in the engine. ect till filter is full.
hugie82's Avatar
hugie82
Always and if its a side mount I will fill it 1/2 way and let it soak in for a minute before spinning it on.
Old Feb 11, 2013 | 03:45 PM
Street Rat's Avatar
Street Rat
Always have and always will. Even on my everyday rice burner.
Old Feb 11, 2013 | 05:39 PM
worship79's Avatar
worship79
Yep. And I allways smear the o-ring with a thin layer of oil too.
Old Feb 11, 2013 | 05:48 PM
MrJlr's Avatar
MrJlr
And check that the old o-ring came off with the old filter!
Old Feb 11, 2013 | 06:24 PM
7t9l82's Avatar
7t9l82
100 percent
Old Feb 11, 2013 | 06:26 PM
Jeff_Keryk's Avatar
Jeff_Keryk
No nay-sayers? Sheesh, you guys are picky...
Maybe I should say I use Rotella T?
I thought by now everybody would be jumping down everyone else's throats.
Oil threads are supposed to ROCK!
Ha!
Old Feb 11, 2013 | 06:34 PM
qwank's Avatar
qwank
yes
Old Feb 11, 2013 | 06:38 PM
7t2vette's Avatar
7t2vette
The ORIGINAL and bestest
Toronto Events Coordinator
Yes, always.
Old Feb 11, 2013 | 06:41 PM
George Ries's Avatar
George Ries
I always put oil in the filter
Old Feb 11, 2013 | 06:48 PM
jb78L-82's Avatar
jb78L-82
Ditto!!
Old Feb 11, 2013 | 07:15 PM
loup68's Avatar
loup68
Army
Always, after a motor head told me to in 1973.
Old Feb 11, 2013 | 07:23 PM
OMF's Avatar
OMF
Nope...never have, and never any problems. The oil film thats remaining is plenty sufficient for protecting the journals during the few seconds of idling that it takes to build pressure.
I even once putted around my property in my racecar for about a minute before I realized I forgot to put in some oil....drove it back to the garage added oil.....raced that weekend and the rest of the season on that engine without any problems.
Flame Away.....Hard hat is on
Old Feb 11, 2013 | 07:28 PM
lonzoo's Avatar
lonzoo
Never have. Actually never it gave it a thought. But after reading the posts it does make sense. Think I will start on next oil change.
To Do you prime your oil filter?
Old Feb 11, 2013 | 07:42 PM
Redwing01's Avatar
Redwing01
2015 C3 of Year Finalist
I'm in the same boat, I never was taught that way and never really gave it much thought. ( always lube the "O" ring though)
I will prime the next one though, just for kicks!
Old Feb 11, 2013 | 07:53 PM
kanvasman's Avatar
kanvasman
never have forever. DO oil up the rubber washer on top, make sure the old one didn't stay up there, never over tighten. Never had a problem. Start it up, let it idle up until you get pressure, check for leaks.
Old Feb 11, 2013 | 07:54 PM
C2C3PO's Avatar
C2C3PO
Absolutely I do ! It was something my dad taught me 40 years ago, never thought twice about doing it !
