Big block water pump
Old Feb 13, 2013 | 09:38 PM
TOM B1's Avatar
TOM B1
Default Big block water pump
On my 69 BB I installed a Edelbrock hi performance water pump #
EDL-8860.
From what I can tell by measuring the inlet diameter =1.95 inches
or 2 inch hose.
Does anyone know what the stock BB inlet hose size is.
I cant find a hose that says its 2 inch on the water pump side and I dont have a stock pump to measure.
Old Feb 14, 2013 | 07:03 AM
BB68Vett's Avatar
BB68Vett
I do not believe you need a special/different lower radiator hose for an Edelbrock water pump. I put an Edelbrock water pump on my 68 big block and the lower radiator hose fit fine. Snug and no leaks.
Did you try the stock hose and it didn't fit or are you just anticipating an issue?
Old Feb 14, 2013 | 07:21 AM
Mooser's Avatar
Mooser
72 Pump measures 1-15/16+ so 2"
HIH
Mooser
Old Feb 14, 2013 | 01:42 PM
TOM B1's Avatar
TOM B1
No I dont have a hose to try. so it is about 2 inch.
I was looking at flexable hose kits
http://www.summitracing.com/parts/sum-390124
but they only go to 1-3/4 inch
Old Feb 14, 2013 | 11:03 PM
BB68Vett's Avatar
BB68Vett
Do you have a stock radiator? If so, you can go to NAPA or some other auto parts store and buy a lower radiator hose for a 69 Corvette with a big block. It should fit fine. Were you looking for something special/different? Just trying to help. :-)
To Big block water pump
