Crush Sleeve
Old Feb 14, 2013 | 11:45 PM
Korevette's Avatar
Korevette
Default Crush Sleeve
I have gotten to the point I will start the final assembly of the pinion shaft/bearings on my '76 differential. I am using a new 'crush sleeve'. From reading many threads I understand it will take a fair bit of effort to tighten the pinion nut to start the 'crush'.
I am afraid my 1/2" Blue Point impact wrench will not get this started. I need some feedback about how to start the crush. I know once that it starts it gets to be a real carefull process to achieve that desired rotational torque.
Has anyone used a hydraulic press with a thick plate on the top of the sleeve pressing down onto another thick plate to start the 'crush'?
Thanks.
Old Feb 15, 2013 | 08:06 AM
oldalaskaman's Avatar
oldalaskaman
your impact should do it
Old Feb 15, 2013 | 08:11 AM
dtamustang's Avatar
dtamustang
Old Feb 15, 2013 | 08:36 AM
76stingracer's Avatar
76stingracer
I started the crush in a press as you described.
To Crush Sleeve
