Idler arm torque spec.
Old Jun 15, 2002 | 12:17 AM
AV76's Avatar
AV76
Default Idler arm torque spec.
I just replaced my idler arm on the front suspension of my '76 and was wondering what the torque spec is for the nut that ties it to the steering linkage. Anyone know?
Second question, the washers that were supplied with the arm are like little foam rings and look like they will compress and probably tear if the nut is tightened very tight. Is this right?
Any comments, related or unrelated would be greatly appreciated.
Aaron
Old Jun 15, 2002 | 02:24 AM
Rods77's Avatar
Rods77
Default Re: Idler arm torque spec. (AV76)
Hope you don't mind if I jump on board with the same question....I too just replaced all my suspension parts a few days ago and can't find that torque spec. :cheers: As for the foam washer...on the idler arm I installed the threaded shaft was a little longer than the one I pulled out. The taper on the shaft looks like it won't allow the shaft to suck up all the way into the hole when you tighten the nut, so that should save the foam washer. Also I'm sure the grease will leak down into there a little and that too will help lube up the washer.
[Modified by Rods77, 10:30 PM 6/14/2002]
Old Jun 15, 2002 | 01:16 PM
78pace's Avatar
78pace
just replaced mine also couldnt find any reference to it in chiltons manual
i tightened mine to 2 veins popped out on my neck :lol:
Old Jun 22, 2014 | 10:56 AM
Tooonz's Avatar
Tooonz
Anybody? I need the same spec, can't believe this post is 13 years old but this is what the search pulled up.
Old Jun 22, 2014 | 11:03 AM
Flyinace3's Avatar
Flyinace3
Idler arm to frame 30ft lbs
Idler arm to relay rod nuts 35ft lbs
Old Jun 23, 2014 | 06:09 AM
Tooonz's Avatar
Tooonz
Thank you very much.
To Idler arm torque spec.
