80 rear control arm removal
Old Feb 17, 2013 | 08:14 AM
Maddan's Avatar
Maddan
Default 80 rear control arm removal
Can anyone tell me an easy way to get the front mounting bolt out of the driver side rear control arm?, my bushing is completely gone and needs to be replaced... Any help would be GREATLY appreciated...
Thanks, Dan
Old Feb 17, 2013 | 09:44 AM
drwet's Avatar
drwet
Nope. Do a search on this site and you'll find that this job is one of the biggest PITA jobs on a C3. Sawzall and a big box of blades is about the best answer you're going to get.
Old Feb 17, 2013 | 09:58 AM
CaseyJones's Avatar
CaseyJones
St. Jude Donor '15-'16
Unless you can soak it in penetrating oil of some kind for several days and then work it loose that way, cutting it is your only choice. I'm doing the same job on my '80 right now. It is truly not the most fun I've have with my car so far.
Old Feb 17, 2013 | 10:35 AM
SuperBuickGuy's Avatar
SuperBuickGuy
It's hard if you follow the buy a box of blades advice..... you only need one, maybe two blades
and one of these
it's a slide hammer with a pin welded on the end to grab the shims and hammer them out.
1) soak the shims in penetrating fluid
2) soak them again
3) remove the cotter pin that keeps the shims in place
4) loosen the bolt holding the trailing arm in place
5) pry the shims up so you can grab the hole
6) slide hammer the shims out
7) cut the trailing arm bolt
the reason I'm not thrilled with the box-of-blades advice is if the shims are rusty enough, they'll get caught in the teeth and vibrate furiously above the trailing arm bolt..... and the bolt won't get even a scratch.
I literally spent days trying to cut through... finally, in frustration, I made that slide hammer attachment. both arms were off in less than an hour.
Old Feb 17, 2013 | 10:54 AM
Maddan's Avatar
Maddan
Thanks guys, I've been a chevy enthusiast for a long time, although this is my first 'vette, wish I'd have visited this site before I aquired this one...I didn't even know about the shims, although, now after looking at it, there seems to be enough play with the bad bushing that i may be abe to get with a sawzall without removing the shims...
Thanks, Dan
Old Feb 17, 2013 | 12:14 PM
lvmyvt76's Avatar
lvmyvt76
there is a web site that shows how to take the control arms completely out, wish I could remember who has it.
Old Feb 17, 2013 | 12:29 PM
doctorgene's Avatar
doctorgene
Van Steel has a Tape for sale, that shows all Suspension, How to remove & replace!! Have a great one. Gene
Old Feb 17, 2013 | 12:35 PM
gbarmore's Avatar
gbarmore
I made a bolt 'knock out' tool from a piece of ~1/4" steel rod I had laying around. I bent it as little as possible in order to get around the contour of the wheel well. If you bend it too much you won't be able to generate the kind of thrust you need to push out the bolt. This worked like a charm, here are the pics.
Best of luck!!
Old Feb 17, 2013 | 01:02 PM
garygnu's Avatar
garygnu
you could try using a dremel tool with a cut off wheel ,and cut the bolt off on the inside of the TA.
Old Feb 18, 2013 | 01:46 AM
Mario Barrios's Avatar
Mario Barrios
Default I was lucky...
Ok...I spent a lot of time reading on this and was dreading doing it. I suppose I'm one of the lucky ones because I had no trouble at all. I didn't know what to expect from my car so I started by spraying some penetrant and soaking for a few minutes. Then I got the nut loose and used a piece of steel rod to knock the bolt through. Couldn't believe my luck. Both sides. Turns out my bushings weren't terrible and I don't know if that is a factor.
I do believe it can be a giant pain. Lot's of experience here on the forum. I figured I'd share my experience to let you know that it is possible to not suffer on this. Be aware that I have a california car so rust is not such an issue. Though my car sat for 17 years and I did have some unsticking to do on my ebrake cable and my ebrakes were just rusted and rotted.
Either way, I was SUPER happy once those trailing arms were off the car. And though mine was easy, I wouldn't have even started if I didn't know the guys on the forum were here to back me up.
(Thanks guys...)
Good luck with the task......
Old Feb 18, 2013 | 08:13 AM
Street Rat's Avatar
Street Rat
@ gbarmore - That is quite a tool that you made there. You should patent it and sell it to forum members.
Old Feb 18, 2013 | 08:44 AM
gbarmore's Avatar
gbarmore
This 'tool' worked when all else failed so I thought it might help the OP. I don't recall you adding anything constructive to this thread, did I miss something??
Old Feb 18, 2013 | 09:24 AM
jakvette's Avatar
jakvette
Hi
Couldnt save any of my shims to measure when i did mine so worked them out with a hammer and chisel until i could get either side of the bushing with a cutting torch and the smallest nozzle i could use .
Had lots of wet rags two extinguishers and buckets of sand at the ready, drained all the fuel from the tank a week before and left the cap off . Put the cap on before cutting the bolt , but it cut fast and with no damage except to the rubber of the bushing .
Quite hair raising and only for the the brave i must confess , i did have visions of my beloved 454 going up in smoke , but all other ways were exhausted and cut fingers and bent pieces of metal bar and the like were a joke . If you cant get some of the shims out to make space for the sawzil you can forget it , although i believe there are some special metal blades that can be bought that will cut through the lot , i couldnt locate any over here .
Good luck i know what your going through .
Old Feb 18, 2013 | 09:58 AM
Street Rat's Avatar
Street Rat
Whoa. I didn't mean to offend you. I think the tool is a great idea. I wish I had something like that when I did mine.
My input on the subject was a while back.
http://forums.corvetteforum.com/c3-t...-arm-hell.html
Old Feb 18, 2013 | 10:01 AM
billcarson's Avatar
billcarson
like mario mine came out relatively easy so no need on my part to make a special tool.it was my enjoyment to create these special tools during my rebuild and great to see forum members SuperBuickGuy and gbarmore's creativity.great work !
Old Feb 18, 2013 | 10:28 AM
Maddan's Avatar
Maddan
The biggest problem I see as of now is accessibility to the nut and bolt... Also, if I cut the bolt, are they readily available?...
Thanks, Dan
Old Feb 18, 2013 | 10:32 AM
gbarmore's Avatar
gbarmore
Yup, they are available from most of the parts dealers you see on the left of the forum pages. They're relatively inexpensive and you should get a new set of stainless shims as well.
Old Feb 18, 2013 | 10:33 AM
billcarson's Avatar
billcarson
yes the beauty of these cars is the availability of parts at reasonable prices.all the forum venders carry them. inexpensive except the prices on interior parts.
Old Feb 18, 2013 | 10:40 AM
jakvette's Avatar
jakvette
Thanks, Dan
Hi Dan ,
I cut either side of the bushing once i got enough of the shims out to see the bolt , i cut mine from the top of the bolt towards the floor with a small cutting torch and nozzle , but if your too scared you can use a sawzil .
Once you have cut either side you can pull out your trailing arms and then carry on with getting out all of the rust and debris from the pockets and take out whats left of the bolts .
If the trailing arms are so badly rusted and seized , i would do the bearings at the same time , not an easy task but there are some great guys that you will come across on the forums who will tell you how , like Gary Ramedei .
You will need to get yourself a shim set , which should come with new trailing arm bolts as well , these are all available from vendors such as zip and ecklers and the other guys as well , sorry if i offended any of the other guys by not remembering the names .
Good luck ,
John
To 80 rear control arm removal
