Engines
Old Feb 19, 2013 | 07:16 PM
blkhrt12's Avatar
blkhrt12
Default Engines
Hello All.. We are looking to upgrade our 1975 engine (getting bored with our 165HP LOL). Looking around 300- 400 HP range. Can anyone tell me from experience which engine/engines may fit the clearance of the original hood? Thanks
Old Feb 19, 2013 | 07:24 PM
wilcar's Avatar
wilcar
Why not have your 75 shortblock rebuilt, add a performane cam and a set of new heads and you will be well over 300hp.
Old Feb 19, 2013 | 07:32 PM
AirborneSilva's Avatar
AirborneSilva
Stroke your original motor.
Old Feb 19, 2013 | 07:44 PM
TedH's Avatar
TedH
Your engine. Warmed over. 300hp easy and your drive train will live fine behind it.
Old Feb 19, 2013 | 07:46 PM
hugie82's Avatar
hugie82
Edelbrock power package is the easiest bang for the buck on a street driven car and they have a dyno chart to show where you'll be after the install
Old Feb 19, 2013 | 08:11 PM
diehrd's Avatar
diehrd
Or look at crate motors from jegs
Old Feb 19, 2013 | 08:22 PM
U17's Avatar
U17
ZZ383 ... You'll need a little bump in the hood ...
Old Feb 19, 2013 | 08:34 PM
AllC34Me's Avatar
AllC34Me
Senior Member
St. Jude Donor '10
I put in a GMPP 350HO, 330HP and no modifications needed to the hood. I also changed out the old engine fan for spal fans installed on an aluminum radiator from Dewitts. Night and day change to my 77.
Good luck with your choice and mods.
David
Old Feb 20, 2013 | 05:14 PM
blkhrt12's Avatar
blkhrt12
Thanks everyone. I guess you could say I LOL really want a new engine. I would feel alot safer driving it to and from work. So I will take everyones advice and look forward to a NEXT winter project... If anyone has any more suggestions I would greatly appreciate them
Old Feb 20, 2013 | 08:03 PM
ajrothm's Avatar
ajrothm
Order you a nice 450hp small block from this guy for under $5k... Drop it in and be done..
http://www.vortecproperformance.com/...binations.html
It will be built right, put you in the 11s and be daily driveable.
I have one of his engines and 2 of my buddies have recently bought engines from Mark... All of them exceeded our expectations...
Old Feb 20, 2013 | 08:06 PM
Jeff_Keryk's Avatar
Jeff_Keryk
A new crate, headers and exhaust. 2 weekends. Go for it.
Old Feb 20, 2013 | 08:56 PM
cv67's Avatar
cv67
St. Jude Donor '05
ditto on vortecpro reliable power
If I had 7 or 8k Id get one of his big blocks hard to beat it for that kind of $.
Old Feb 21, 2013 | 09:52 AM
Darrel1's Avatar
Darrel1
David
What exhaust manifolds did you you with this engine if you dont mind me asking? I am looking at this same engine for my 1980.
Thanks Darrel
Old Feb 21, 2013 | 09:59 AM
johnt365's Avatar
johnt365
In my experience, the things that leave me stranded are not the motor. I have never blown a motor but accessories fail, alternator, starter, water pump, fuel pump... These are things you will want to factor into the upgrade for reliability. A crate motor will have some of those but not all.
You also want to take in to account your transmission type and gearing and your rear end gear ratio. Set a goal for the car and make those three systems work together.
300hp with 3.08's and a th400 can still be a drag if the cam comes in too late.
For a daily driver, an overdrive transmission would change your life.
If I were shopping for a motor, I would ask for a dyno print out (if possible) of the motor and see if my drive line components would let me get in the power band reasonably on the street.
Old Feb 21, 2013 | 02:55 PM
PaPaPork's Avatar
PaPaPork
You have to figure out what kind of power are you after, to do so the best thing to do would be to drive, even as a passenger in different cars of that era with different engines (neighbors, car clubs etc) Full rebuild with the Edelbrock package would run pretty expensive and will not give the expected results. I have one, and even with 4.11 the car is slow on the street, sure it sounds fast but a 15 yo F body or a Civic Si will drive around me. I don't think its worth to invest 5k or whatever into the current engine if it will only sound fast. I would say go for a Crate stoker, with that said, go for a turn key, dynoed engine. and ask if the power is NET. New/ rebuild engine is a big investment so its better to toss 1k or 2k extra than to be disappointed.
Old Feb 21, 2013 | 04:00 PM
63mako's Avatar
63mako
St. Jude Donor '08-'09
It all sounds good but they are not as advertised. Cams are to big. Head flow is short and they need more compression than an L48 will provide with a powerband higher than the stock internals and gearing will match up with. Poor choice unless you have a low mile L82 with a low gear.
Old Feb 21, 2013 | 04:01 PM
63mako's Avatar
63mako
A 5 speed manual conversion, Headers, free flowing exhaust, a good tune and distributor recurve will totally change the car and likely will not have the need to swap engines until the more power bug bites you again. Then your all ready for a real upgrade. So many guys think a high HP engine is the answer and spend $5-10,000 only to be disappointed because the gearing is a total mismatch for the new engine. At this point many are no longer in a position to upgrade the rest of the driveline.
To Engines
Old Feb 21, 2013 | 06:09 PM
blkhrt12's Avatar
blkhrt12
You all rock! Thank you so much for all your input. Right now we have some Excellent stainless Hooker Headers/Side mount exhausts and the car "sounds" awesome.. Now we want it to run awesome.. We have been looking at the Stoker dressed package, it looks good to me, but what do I know LOL. Yea I hear ya a manual conversion would kick *** too. Ajrothm- thanks for your info and by the way "nice car" my uncle has one exactly like it!!! 1971????? I will keep you all posted Thanks again... Stacey
Old Feb 21, 2013 | 08:27 PM
garygnu's Avatar
garygnu
consider a comp cam ex268h cam and a elderbrock rpm performer intake .consider some dart iron heads from competition products.I have seen sbc 383 short blocks for $1800+ shipping.
Old Feb 22, 2013 | 01:21 PM
PaPaPork's Avatar
PaPaPork
Go with the strocker!!! manual would be nice but its no easy walk in the park, consider a manual valve body automatic so you can change gears by hand without all the heavy mods, like frame cross-member etc...
