Brakes fade
Old Feb 20, 2013 | 05:07 PM
Captain bob's Avatar
Captain bob
Default Brakes fade
I have 1971 convertible trying to find source of brake failure.went thru system replaced all four brake hoses ,rear brake lines replaced,master cylinder,pads and calipers look good . Car does not pull one way or another Manuel brake pressed to floor with maximum effort does not lock up wheels. Rear calipers seem to have poor brake fluid pressure when bleeding. Brake fluid drools out instead of pissing out like front does.anybody know where to start troubleshooting ?
Old Feb 20, 2013 | 05:16 PM
MelWff's Avatar
MelWff
Have you replaced the brake proportioning valve? Stock wheels and tires?
Old Feb 20, 2013 | 06:02 PM
Captain bob
stock wheel and tires but i look at that valve and wonder if it somehow became clogs when i sent all that contaminated fluid thru it when i chaged master brake after sitting for 10 years.
Old Feb 20, 2013 | 07:42 PM
7T1vette's Avatar
7T1vette
It may be contaminated....or it may have just shifted over so that only one half of the system is now working. If that is the case, the blue "BRAKE" light should be showing. (If the bulb is burned out, there will be no light, of course. Check for this light to come on when you turn the ignition key to "ON" position, before you start the engine.)
Also, the brand/type of brake pads you are using is one of the biggest variables regarding brake stopping power. If you have the run-of-the-mill pads from the "Zone", don't expect much of the brake system.
Old Feb 20, 2013 | 08:10 PM
Captain bob
Just check the car , there is no blue light Nor was I aware there was a brake indicator light to begin with.the proportioning valve does have a clean electrical connection but circuitry or bulb is at fault apparently.i will change both engine and a/c heat wiring harness shortly. I am old school and do not shop box stores or zone Chinese knock off junk.ihave had many corvettes over the years and sold the garage queen 1967 big block coupe . This 1971 convertible will be driven any suggestion on brake pads.
Old Feb 20, 2013 | 08:14 PM
Jud Chapin's Avatar
Jud Chapin
St. Jude 15 Year Donor
St. Jude Donor '11 thru '25
Is your brake fluid fresh? Also, I had a similar problem with my '76 where the wheels wouldn't lock up. This was after I replaced the master cylinder as you have done. What happened was when bench bleeding the m/c, I just couldn't get all the air out of it despite bleeding it many times. Someone on the forum told me it was nearly impossible to completely remove all air from it and to just drive the car (safely) and that the brakes would soon operate normally. As it turned out, he was correct as shortly thereafter the wheels could be locked up upon hard breaking. I hope this is of some help to you.
Old Feb 20, 2013 | 08:20 PM
Captain bob
I remove and replaced master cylinder .dumped fluid and kept running dot3 synthetic fluid thru bleeder until spotless. However front bleeders like water pistol and all four rear bleeders dribble out.
Old Feb 20, 2013 | 09:05 PM
CaseyJones's Avatar
CaseyJones
St. Jude Donor '15-'16
Link is truncated and does not work...
Old Feb 20, 2013 | 09:13 PM
CFD E59's Avatar
CFD E59
I was leaning towards the Proportioning Valve, mis-positioned. I would start there. Good Luck
Nice write up Ed-T.
Old Feb 20, 2013 | 09:33 PM
Mike Ward's Avatar
Mike Ward
There is no blue light. There's a red light that also serves as the warning for the e-brake.
Old Feb 21, 2013 | 09:45 AM
Captain bob
Mike thank you for the tip." E- brake same light" yes that red light works fine when e- brake is applied and ED's tip on volt meter shows p- valve good however the analysis with front and rear brakes still show correct fluid stream front and dribbling rear. I order new p- valve anyway.clearly indicates car is stopping by front brakes only . All functions are correct with rear calipers they both apply and release evenly but pressure is almost nil.
Old Feb 21, 2013 | 10:49 AM
7T1vette's Avatar
7T1vette
Mike Ward is correct; the "BRAKE" indicator is red. It's the 'brights' headlamp indicator that is blue. My [memory] error.
Old Feb 21, 2013 | 11:14 AM
my 76 ray's Avatar
my 76 ray
That sounds like air in the rear brake system. There are two bleeder screws on the rear calipers. Are you bleeding the inner ones first? If you do the outer bleeders first you will not get all the air out of the calipers.
Old Feb 21, 2013 | 11:38 AM
Captain bob
Another tip ;.bleed inside first . I did not know that either ihave been away from the corvette building seen for 20 years---------- thank ypu
Old Feb 21, 2013 | 12:06 PM
noonie's Avatar
noonie
Loosen or remove the rear brake line from the differential valve and test for full flow there first.
If not full flow, then try to reset (center) the valve and test again.
They can and do get crudded up internally, but since they are of all (other than spring and rubber) brass construction, replacement is rarely necessary.
Old Feb 23, 2013 | 01:03 PM
Captain bob
I did not forget you Noonie I am waiting for new p- valve to come by ups. I want brakes to be as best they can be. I am best friends with sheriff so I put down top take it to straight two lane eastbound road and he calls up ahead so I can let her go.first time took her to 120 mph and rear was not stable ( for some reason no sway bar in base 350 sbc)I installed 7/8" bar and corrected problem but brakes were terrible now I will try to find source of problem so new p-valve,new brake hoses, new brake lines. Then retest ,thank you and the test of forum for taking the time to help me.----------- captain bob.
Old Feb 23, 2013 | 02:02 PM
aaroncorvette's Avatar
aaroncorvette
It took us a long time ( and a lot of fluid!) to get the air out of the rear brakes, ended up going back and forth from the inner to the outer nipple to get the air out, it seemed it was all out then more would come. I had a 5ltr bottle and went through half of it doing the backs.
Oh and others have said, cheap pads are pants
Get something like Hawk, EBC etc
To Brakes fade
Old Mar 1, 2013 | 11:37 PM
Captain bob
i purchase hawk brake pads i find it odd the front and the rear are the same? have not install yet because i open a can of worms! the piston seals are leaking and all four rotors are oem with rivets 56,000 miles on rotors and they measure 1.290 .show very little wear almost non existent however they are glazed up front and rear left inner was soaked with brake fluid .i believe rear brakes added nothing to stopping power. i am looking into SS sleeved with O-ring calipers and remove and just break glaze on rotor due to no wear.
Old Mar 2, 2013 | 09:21 AM
gcusmano74's Avatar
gcusmano74
Generally, don't mess with the rotors, unless there is absolutely something wrong with them.
My car has 171,000 miles on it now, and the rotors have never been cut. They are still flat, smooth and in great shape.
Old Mar 4, 2013 | 10:30 AM
Captain bob
Wow 171,000 miles on rotors ,somebody took a lot of car changing pads before metal to metal occur. Best statement "if it ain't broke don't fix it" I will leave well enough alone with respect to rotors but ordered DIY kit for SS pistons and O-rings in calipers because car sits in winter months.nice to get into the real nuts and bolts again after i sold that 1967 big block coupe sitting in garage deteriorating for 32 years.never liked that car 427" 400hp tri- power, no air suffocating car in summer with heat coming thru firewall when you use it and bicycle tires on it. That would brake loose while parking!
