1970 Coil Spring Design
Old Feb 21, 2013 | 01:19 PM
Tom454's Avatar
Tom454
Default 1970 Coil Spring Design
Just removed the original coil springs (tag HV 3931826) and they are different lengths. Never saw a Corvette front end with 3 coil springs.
This explains why the car sat lower on the drivers side. And I thought I only needed to lose a few pounds.
Old Feb 22, 2013 | 08:08 AM
71scgc's Avatar
71scgc
How did it sound when you started pulling that broken spring? I bet you were lowering your jack thinking "What the hell is all that racket?"
Carter
Old Feb 22, 2013 | 10:13 AM
7T1vette's Avatar
7T1vette
Well, the spring on the right (two pieces) has a fatigue fracture through it where those two pieces would join. And, you can see the same amount of corrosion on the rest of the part as where that fracture took place. So, it's been that way for a long time...maybe not so long after it was built, if there was a bad inclusion in the metal at the location of that fracture.
I suspect that you did get some 'funny' noises from that right side whenever the spring was needed to flex a lot. The right side on your car should have sat somewhat lower; the shock absorber was the only thing keeping that broken spring in there. Suprised you didn't see it when you changed oil.
Old Feb 22, 2013 | 11:12 AM
SuperBuickGuy's Avatar
SuperBuickGuy
It's really rare, I hear collectors will pay top dollar for a car with that rare-factory spring set.
They only did it on one side because they were trying to balance the weight on the corners.
Old Feb 22, 2013 | 11:18 AM
71scgc's Avatar
71scgc
I can see where the broken section could have been obscured by the spring pocket, thus making it difficult to see on normal viewing. Regardless of how long it's been that way, it's good you found it.
Old Feb 22, 2013 | 12:41 PM
Tom454's Avatar
Tom454
Carter
Funny you should mention that...
I owned a 71 LS5 before this LS5. I tried the same method (jack lowering) on the 71 LS5 as I had used on my C2 327 no air car. Ended up in the hospital with a crushed hand. The BB springs will kick your fanny given the chance. So... I bought the OTC 7045B coil spring tool to pre-empt another visit to the emergency room for the 70 LS5. Even my wife agreed it was worth the money. And that's equivalent to hell freezing over. Tool worked perfect.... just sucked that baby right down.
Old Feb 22, 2013 | 12:44 PM
Tom454's Avatar
Tom454
Good eye... that's exactly what happened. I didn't see the break until the lower portion was mostly compressed. The broken section just sort a followed the other section down slowly. My biggest problem now is finding a replacement set, Nobody has the right spring. I'm gonna have to bubba it.
Old Feb 22, 2013 | 12:45 PM
Tom454's Avatar
Tom454
Well... that changes the game plan. I'm gonna have to glue the label back on that I tore off.
Old Feb 22, 2013 | 12:48 PM
Tom454's Avatar
Tom454
The fracture was up in the spring pocket. I knew something was wrong, but I didn't know what. The drivers side sat low since I owned thw car.
Old Feb 22, 2013 | 04:23 PM
Red Vert 02's Avatar
Red Vert 02
Have you checked with Eaton Spring ? You can check their catalog on the their web site.
Old Feb 22, 2013 | 04:35 PM
spinadog's Avatar
spinadog
Tom, I replaced my BB springs with aftermarket ones and was very happy. This was about 2 years ago. I bought them from Willcox from memory. I have a *perfect* stance on the front and they were so easy to put back in. If you are on the fence about compatibility, fear not. I can dig out the original receipt if you are interested.
Old Feb 22, 2013 | 04:52 PM
Tom454's Avatar
Tom454
No- I had not. I sent them an email. Thanks for the info.
Old Feb 22, 2013 | 05:00 PM
Tom454's Avatar
Tom454
Sure... a part number would be good. Thanks. I don't want to lower the car though.
This car has A/C so it needs the "bigguns". The Moog 5762 (474's 331318) supposedly won't work with A/C cars.
Wilcox #40608: 1963-82 Performance Coil Springs give you even greater handling capacity, and lower your Corvette approximately 1" while upgrading to F-41 specifications.
Old Feb 22, 2013 | 05:22 PM
spinadog's Avatar
spinadog
I found my original posting. the side profile photos clearly show the front end height.
http://forums.corvetteforum.com/c3-g...e-opinion.html
and no, mine's a restoration not a modification. She's perfect, according to a boatload of Vette specialists.
Old Feb 22, 2013 | 06:22 PM
Tom454's Avatar
Tom454
Nice job!
Old Feb 22, 2013 | 06:58 PM
69FASTFUN's Avatar
69FASTFUN
A little DUCT TAPE and your good to go!!!!!
Old Feb 22, 2013 | 08:13 PM
spinadog's Avatar
spinadog
Nice job!
Thanks man! I looked at my previous orders from Willcox and the part number was 5762-36832 68-74 BB NO A/C.
Good luck and remember to get those springs aligned with the pocket correctly!
Old Feb 23, 2013 | 08:37 AM
Tom454's Avatar
Tom454
... I looked at my previous orders from Willcox and the part number was 5762-36832 68-74 BB NO A/C.
That's kinda what I figured. The issue is the A/C. It adds a lot of weight to the front end. Thanks for taking the time to look that up. Just ordered a bunch of stuff from Wilcox... but not the springs. Still trying to find a good match to the OEM set. Found one company who will make a perfect match set for $180. That's kinda high. I'll pass on that one for now.
FYI... the 5762's are Moog and they are $49.95 at Summit.
Old Feb 23, 2013 | 10:17 AM
SuperBuickGuy
the Moog springs are what is on my C3 - I cut 1 1/2 coils off to get the car lower; but, I did put them on my car and the nose was pretty high - I wonder if they'd work just fine on your car... A/C adds 80 lbs., the BBC adds 175 (255lbs total) - which really isn't that much in the great grand scheme of things.... and I like how the car is balanced, too stiff of spring on the front and your feet will travel up and down at a different rate than your seat - which is a pretty disconcerting feeling...
also, spring rate is determined by wire diameter (and number of wraps, of course) - your springs look to have about the same diameter as mine....
apparently I didn't take a picture of the spring while it was out... but here's that Moog spring
To 1970 Coil Spring Design
