bonehead lessons learned
Old Feb 24, 2013 | 10:25 AM
commander_47's Avatar
commander_47
Default bonehead lessons learned
OK OKOK OKOK for a couple of weeks now been wrestling with this silly heater fan hookup.
checked and double checked everything (I thought).
Posted two pleas for help on the forum. Several of you graciously jumped in with suggestions which I promptly tried.
It was when I took apart the console to do a continuity check on the switch that the problem was staring me right in the face.
One of those issues you have to look twice. Then even a third time. Then it comes .....Oh S--t. Noooo, that can't be it. Not me!!! Surely not me.
Well....when I first hooked up the switch I pushed the plug in enough to test it and see that all worked fine. Then I put the rest together.
After it was together is when it didn't work right. Only the low would run. Would run all the time. On all settings.
Well.....the hard learned lesson here. After testing, make sure the plug is pushed up ALL THE WAY, or it will fall off.
When you are done laughing.....look in the mirror and tell me you haven't done something similar
Old Feb 24, 2013 | 10:47 AM
hugie82's Avatar
hugie82
Not really sure what you missed or messed up on but yes! We've all been there
Old Feb 24, 2013 | 11:36 AM
oldgoat99's Avatar
oldgoat99
I have to admit that I did make a mistake once..... I thought I was wrong about something and as it turned out, I wasn't.
Old Feb 24, 2013 | 12:09 PM
drwet's Avatar
drwet
We should have a whole section where we can share all the stupid s**t we've done. I once poured four quarts of oil right through an engine. Didn't realize I forgot to put the drain plug back until I noticed I was standing in a puddle of fresh oil.
Old Feb 24, 2013 | 01:22 PM
RodgerF's Avatar
RodgerF
Who me? Er, ah... no! LOL I've probably done it all at least once.
Rodger
Old Feb 24, 2013 | 01:35 PM
CA-Legal-Vette's Avatar
CA-Legal-Vette
We should probably begin all trouble shooting exercises by repeating this three times
Old Feb 25, 2013 | 08:55 AM
oldC3guy's Avatar
oldC3guy
Drwet,
Only 4 quarts? Ha! I poured 6 quarts clear through and into the drain pan with the 6 quarts I had just drained out.
Old Feb 25, 2013 | 10:33 AM
SuperBuickGuy's Avatar
SuperBuickGuy
nope, never made that mistake
there are rumors, however, that I've made other mistakes.... JUST RUMORS.... but I never made THAT mistake
Old Feb 25, 2013 | 11:29 PM
drwet's Avatar
drwet
Originally Posted by oldC3guy
Drwet,
Were you lucky enough to have a 12 quart drain pan?
To bonehead lessons learned
