Shift linkage
Old Feb 26, 2013 | 04:50 PM
Capt Ken's Avatar
Capt Ken
Default Shift linkage
Bit of confusion. Using the GM overhaul manual, I adjusted the shift linkage with the shift rods in the center holes on the shift levers. This is how it was set up when I pulled it out. Looking at the assembly manual, it shows the linkage should be in the end holes. Maybe that is why it was jumping out of gear....need rebuilding anyway, so not sorry I pulled it. Which is correct? Does it matter? Should I be crawling back under to readjust the linkage?
Old Feb 26, 2013 | 05:07 PM
MelWff's Avatar
MelWff
The top holes are long throw the middle holes are short throw. Factory set it up for long throw. I have mine set for short throw.
Old Feb 26, 2013 | 05:11 PM
gcusmano74's Avatar
gcusmano74
Yes.
I prefer the short throw myself. The effort is just a bit higher than the long throw, but easy to get used to.
Double check your adjustment. It shouldn't jump out of gear. No way.
If your tranny is shot now anyway, think about replacing it with an overdrive 5 speed.
Old Feb 27, 2013 | 09:49 AM
Capt Ken's Avatar
Capt Ken
Default re
Thanks! I too prefer a short throw.
Old Feb 27, 2013 | 10:27 AM
Brcmpbl's Avatar
Brcmpbl
Can the linkage be adjusted / shifter moved to the short throw position without pulling the transmission? I want to take a stab at this at some point in the near future.
Old Feb 27, 2013 | 02:09 PM
Jims427400's Avatar
Jims427400
Im going to make the same adjustment on my 67 and 68 to the short throw. I plan on just putting car in neutral and then adjust all the rods to fit in lower holes. That way it should still be in adjustment when your done. If that doesn't sound right to anyone let us know.
Jim
Old Feb 27, 2013 | 03:13 PM
gcusmano74's Avatar
gcusmano74
Jim
Old Feb 27, 2013 | 05:23 PM
Brcmpbl's Avatar
Brcmpbl
Sounds like it can be done with some ramps or jack stands.
Old Feb 27, 2013 | 09:59 PM
Petes73's Avatar
Petes73
There is a slot in the shifter that a gauge/pin goes in to hold the shifter in place while you adjust it. You can make or buy one. You will never get it right if it is floating free.
Old Feb 28, 2013 | 09:07 AM
Capt Ken's Avatar
Capt Ken
Default pin
a diagram of the shifter tool is in the GM maintenance manual. Away from the house for a couple days so I can't post the dimensions. I made mine with tin snips in about 5 minutes. I did mine on jackstands.
To Shift linkage
