Carb problems?
Old Jun 16, 2002 | 02:58 PM
SLICKMAN's Avatar
SLICKMAN
Default Carb problems?
Well, after 7 hours of changing Plugs, cap, rotor, wires :eek: , gas filter, air filter and checking timing its running much better!! When I replaced the wires I had to take off all the wire shielding and drop the starter but I did it the right way. It took 3 1/2 hours just to change the wires!! :eek:
I still have an erratic pulsing when I’m cruising along that I thought would clear up.. I think I have some minor carb problems going on….
Carbs are not my bag so, time to ring her in to the Doctor!!
[Modified by SLICKMAN, 4:09 PM 6/16/2002]
Old Jun 16, 2002 | 03:29 PM
page62's Avatar
page62
Default Re: Carb problems? (SLICKMAN)
Have you tried a can of fuel system cleaner? Go for the good stuff. If it works, great! If not, you're out a few bucks, but you'll have cleaner valves...
Old Jun 16, 2002 | 03:42 PM
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
Default Re: Carb problems? (page62)
Is it orignal carb, 24 years old ?
Could need a rebuild if that's the case
Old Jun 16, 2002 | 05:13 PM
SLICKMAN's Avatar
SLICKMAN
I'll have to try the carb cleaner and see if that helps.. Its the orginal carb (just about 25 years old) but it only has 27,000 on it.. But sitting around that long I'm sure took it toll.
Old Jun 18, 2002 | 11:54 AM
fontking1a's Avatar
fontking1a
A pulsing could be a bit of dirt in one of the passageways of the carb. It could even be a small piece of gasket material. If the carb is old and the gasket material hasn't been updated to the new fuel type....the gaskets could be disintegrating within the carb itself.
To Carb problems?
