throttle cable replacement
Duane
You should change the pedal assy to a 70 and up. Much better than the 69. The cable has a 1/4x20 bolt that bolts in from under the dash. It holds it tight to the firewall. The rest is common sense.
By | 2026-06-03 10:34:17
By | 2026-06-03 10:21:50
By | 2026-06-03 15:43:40
By | 2026-05-28 09:31:39
By | 2026-05-27 17:20:09
By | 2026-05-27 16:54:53
By | 2026-04-03 00:00:00
By | 2026-05-20 07:23:03
By | 2026-05-12 16:54:12
By | 2026-05-11 09:50:51
