found missing ground
Old Mar 5, 2013 | 03:44 PM
7t9l82's Avatar
7t9l82
Default found missing ground
i have had several screwy things wrong with the gauges dim dash lights, erratic gauges, and other things. starting as far forward as possible it didn't take long, a black wire coming out of the convoluted tubing with the green horn wire was cut . i stripped it back and found a good spot to ground it, now it seems all is well. i can't believe a ground that far off would have an effect. now i will look closer there has to be a reason that helped.
Old Mar 5, 2013 | 07:40 PM
worship79's Avatar
worship79
Sounds very interesting, alas the picture isn't visible.
Old Mar 6, 2013 | 10:03 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
I'm not sure what you found, but the forward lamp harness on C3s has a factory ground out by the head lights which screws to the radiator support. The AIMs show it. Dash harnesses ground on the driver's hinge post.
Old Mar 6, 2013 | 11:34 AM
7t9l82's Avatar
7t9l82
yes, i was aware of both of those , the harness for the headlights and the horn are all bundled into convoluted plastic . where the green wire comes out for the horn there is a black ground wire. that is what was not connected. it shows it in a book i have in the schematic. it looks like someone was in there and tore it free.it definitely has helped. now i need to check else where just in case
Old Mar 8, 2013 | 09:02 AM
worship79's Avatar
worship79
A picture would be worth a lot!
Old Mar 8, 2013 | 09:09 AM
7t9l82's Avatar
7t9l82
im really not good at posting pictures, i am planning on taking a class at apple to help me with it. everyone said buy an apple, well i think they are overrated! same people would probably drive a prius!
Old Mar 9, 2013 | 04:41 PM
worship79's Avatar
worship79
Lol, now there's a snakepit (I agree btw)
Hope the class helps!
To found missing ground
