THM-350 or THM400?
Old Mar 11, 2013 | 10:32 PM
7vette6's Avatar
7vette6
Default THM-350 or THM400?
Which one is better? I thought the 350 came out after the 400, but that confused me a bit
and I am reading that the 350 has slightly higher 1st and 2nd gear ratios's compared to the 400, this means slightly slower acceleration right?
350
1st: 2.52:1
2nd: 1.52:1
3rd: 1.00:1
Reverse: 2.07:1
400
First Gear - 2.48:1
Second Gear - 1.48:1
Third Gear - 1.00:1
Reverse - 2.07:1
Old Mar 11, 2013 | 11:03 PM
DRIVESHAFT's Avatar
DRIVESHAFT
The 400 is heavier and stronger.
The 350 is a bit lighter, and slightly quicker to accelerate.
For the average driver, any difference in performance will not be something that can be noticed.
Old Mar 11, 2013 | 11:06 PM
7vette6's Avatar
7vette6
gotcha, just wanted to know some of the differences.
thanks
Old Mar 11, 2013 | 11:15 PM
7T1vette's Avatar
7T1vette
The 400 is essentially 'bulletproof'; the 350 is not, unless modified with some stronger parts. Neither is an 'efficient' auto transmission...they are fuel hogs, but they are good for what they are.
If you are going to do much highway driving, and overdrive tranny is a better choice: 200-4R or 700R4. And, as with the 350, they need to be upgraded on specific parts if you are going to throw a lot more torque through them. With the overdrive [high] gear (.67:1), you can do about 20% better on fuel mileage with the same vehicle.
Old Mar 11, 2013 | 11:53 PM
7vette6's Avatar
7vette6
yea Ive done some long distance driving at some high speeds, in hindsight my tranny was probably begging me to stop. 3 spds
Old Mar 12, 2013 | 12:12 AM
Ibanez540r's Avatar
Ibanez540r
The 400 also takes substantially more torque to spin compared to the 350.
Old Mar 12, 2013 | 01:41 AM
lance m p's Avatar
lance m p
Default The man is right the 400 is bullet proof..........>
Arguably the strongest automatic built by the BIG 3 is the 400 turbo 1st, C-6 2nd and the 727B torqeflite 3rd in strength and durabilty. The 400 would take more hp and torque to turn meaning less rearwheel hp. in a BBC or a fully built SBC yes for a more mild street car w/a SBC I would use a R47OO or a 2004R [My street/strip car [T/Buick 3.8 TI-SFI] runs mid 10's @ over 125mph in the 1/4 w/a 2004R, [built] the good thing about the 2004R is if your car has a 350 turbo in it a 2004R will pretty much bolt in w/some mods to the crossmember-w/the 2004R you won't havta cut your driveshaft, w/the R4700 you will> the case is longer. Plus if you drive your car alot at hwy speeds you'll get much better mpg AND less stress on the engine, because the engine will be operating at a lower rpm range. And both above mentioned overdrive units have a good low 1st gear with the benifit of overdrive.
Old Mar 12, 2013 | 01:50 AM
lance m p's Avatar
lance m p
Default Something to think about..............>
Originally Posted by lance m p
Arguably the strongest automatic built by the BIG 3 is the 400 turbo 1st, C-6 2nd and the 727B torqeflite 3rd in strength and durabilty. The 400 would take more hp and torque to turn meaning less rearwheel hp. in a BBC or a fully built SBC yes for a more mild street car w/a SBC I would use a R47OO or a 2004R [My street/strip car [T/Buick 3.8 TI-SFI] runs mid 10's @ over 125mph in the 1/4 w/a 2004R, [built] the good thing about the 2004R is if your car has a 350 turbo in it a 2004R will pretty much bolt in w/some mods to the crossmember-w/the 2004R you won't havta cut your driveshaft, w/the R4700 you will> the case is longer. Plus if you drive your car alot at hwy speeds you'll get much better mpg AND less stress on the engine, because the engine will be operating at a lower rpm range. And both above mentioned overdrive units have a good low 1st gear with the benifit of.......overdrive.
The 86-87 GN-T/Type Regals were the fastest production cars built in U.S.A. in that 2 yrs-period.....Mustang/Vette included. And GM used the 2004R in those cars including the baddest of the bad the GNX.
Old Mar 12, 2013 | 06:25 AM
aaroncorvette's Avatar
aaroncorvette
What rear gears do you have?
Personally i'd go for a TH200 if you can, better 1st gear and an overdrive
Old Mar 12, 2013 | 08:39 AM
DRIVESHAFT's Avatar
DRIVESHAFT
And they still made less than 300 hp.
Old Mar 12, 2013 | 09:32 AM
gerry72's Avatar
gerry72
Just to be clear, there is a TH200 (metric trans) and TH200-4R. The TH200 is a three-speed very light-duty replacement for the TH350 and would be a disastrous mistake. You did state "overdrive" but if you go junkyard shopping for a TH200, you just might end up with one.
Old Mar 12, 2013 | 10:25 AM
aaroncorvette
Sorry I mean't TH200R4
To THM-350 or THM400?
