I have a 74 vette (350). the previous owner had changed from points to electronic ignition. Looking at it closley the other night I noticed that he still had the resistance wire run to the external coil. If the distributor is not recieving the full 12v could this effect the way the car runs? Thanks.
From: I tend to be leery of any guy who doesn't own a chainsaw or a handgun.
Depends. The electronics rarely need or want the resistor (assuming the module is being fed from the coil C+ terminal), but chances are the coil still does.
Please read the Ignition sticky, and it will explain why the resistor may still be necessary.
You have to know what manufacturer made the unit and then you can get the instructions explaining whether it should get full voltage or use a resistor.
The stock coil is not rated for full time 12 volts. Normally, the coil only sees 12 volts while the starter is engaged. As soon as the engine starts, and the starter disengages, the coil is powered through the resistance wire, and only sees maybe 9 volts.
You can buy coils in the aftermarket that are rated for full time 12 volts. Because the initial voltage is a bit higher than stock, these coils will deliver a slightly higher voltage to the plugs. Just add a jumper wire to the coil that is controlled by the ignition switch. And you can then ignore the resistor wire.
These coils are "happiest" when they see the full 12 volts. If the fuse on your jumper wire blows, the car will feel a bit down on power.
Different brands/models of those electronic ignition systems are designed to use either the stock voltage feed from the resistance wire OR a direct 12 vdc signal. You will have to query the manufacture of the device you have installed to determine how it should have been wired.
If that device should have received 12 vdc, and you want to keep it, then you need to run a [non-resistance] wire of adequate size from the coil terminal to the point where that resistance wire exits the firewall. Just tap into the resistance wire at that point, then run the regular wire to the coil. You can then cap and wind up the rest of the resistance wire and tie-wrap it somewhere so that you still have it if you ever want to go back to "stock" wiring again.
P.S. While that resistance wire may, in fact, reduce the voltage getting to the coil, its purpose is to limit the current that the coil receives so that it will not overheat/cook. Also, if you do retain that electronic device, the coil you choose should be compatible with it. Likewise, you should have a stock coil, if you keep the resistance wire and stock points system.
Twelve volts is a piece of cake for any stock coil. For heaven sakes, it gets hit with several hundred volts on the primary winding every ignition firing. What the coil doesn't like (or isn't rated for) is high current levels. That's what burns out a coil, not minor stresses like 12 volts.
My stock 44 year old ignition coil has run for decades with the ballast wire shunted. It's still just as happy as it was the day it left St. Louis.
Please read the ignition sticky.
Please provide the link to the Ignition sticky as I have seen this referenced for several issues - thanks
