Stock shifter hits console
Old Mar 12, 2013 | 03:54 PM
billsfan's Avatar
billsfan
Default Stock shifter hits console
The stock shifter in my '76 hits the front of the console in first and third gear. Straight up in neutral, there is a 1 1/2" gap to the front edge of the opening, and 3" gap to the rear edge of the shifter opening. The console is seated into the 2 bolts on the gauge cluster, which is pushed back as far as it could go. I see no way to adjust anything. The shifter arms were installed correctly. The only thing I can think of is to remove the rear radio support, which might allow me to push the gauge cluster back a little. I only need about 1/4" to clear the console.
Old Mar 12, 2013 | 04:03 PM
MelWff's Avatar
MelWff
do the arms on the transmission shift levers have a second set of holes for adjusting to a short shift?
Old Mar 12, 2013 | 04:53 PM
Alan 71's Avatar
Alan 71
Hi bf,
After you take a look at the shift levers as Mel suggestions... is the fit between the rear of the shifter console and the e-brake console typical?
That might give you a clue as to whether the gauge cluster bezel is in the right place.
It's pretty easy to end up with the gauge cluster not quite in the right place.
Good Luck!
Regards,
Alan
Old Mar 12, 2013 | 05:05 PM
billsfan's Avatar
billsfan
Alan, The e-brake console is a tight fit. I've had the whole interior out in the past, including the whole dash. I don't recall if the shifter hit before I did that work. The only thing that secures the bottom of the gauge cluster is the radio support. I may try to remove that support and move the gauge cluster forward a little.
Mel, I don't recall having a second set of holes in the linkage, but it is stock linkage.
Old Mar 12, 2013 | 08:41 PM
gcusmano74's Avatar
gcusmano74
If you look at the shifter bracket, where it fastens on to the rear transmission mount, there are two bolts on the horizontal suface that hold down the front of the bracket. You can remove those two bolts (loosen the rear bolts a bit for now) and shim the front of the bracket up with washers. You may need longer bolts to do this. It will rotate the entire shift handle upwards and rearwards, and away from the front of the console.
You will have to slightly readjust all three shift lever rods when you are done.
I did this at the same time I shortened the throw, and for me, it's a much better fit.
Old Mar 12, 2013 | 08:48 PM
petdoc's Avatar
petdoc
Mine hits in 1st and 3rd, too....
Old Mar 12, 2013 | 09:02 PM
trw's Avatar
trw
Here is a pic.
Hope this helps.
Terry
Old Mar 12, 2013 | 09:28 PM
20mercury's Avatar
20mercury
Default Yep,
Originally Posted by trw
Here is a pic.
Hope this helps.
Terry
That is what I did on my 76 too. Stick was hitting the console so I added and substracted shim washers until I got the stick centered just like the AIM shows.
Old Mar 12, 2013 | 09:52 PM
63split63's Avatar
63split63
Check that the nuts that secure the shift arms on the shift forks are tight . If they are a little loose and the slot in the arm is a little sloppy the shifter will hit the console .
Bill
Old Mar 13, 2013 | 10:21 AM
billsfan's Avatar
billsfan
Thanks guys for all the tips. I was looking for a way to adjust the shifter location, you guys are the best!
Old Mar 13, 2013 | 10:28 AM
hugie82's Avatar
hugie82
The stock shifter was always loose and sloppy after 50,000 miles. I would look for warn linkage pins and holes. I had to weld and grind 2 rods on my 74. I cut the shifter throw down almost an inch.
Old Mar 14, 2013 | 10:09 AM
billsfan's Avatar
billsfan
Actually, I rebuilt it with a shifter kit from Zip a few years ago. I used the thick spacer. It's nice and tight and shifts great. Scraped off 30 years of of Chevy's patented rust prevention system!
To Stock shifter hits console
