Dreaded rod knock, how do you test?
Old Mar 13, 2013 | 04:48 PM
Surfer69's Avatar
Surfer69
Default Dreaded rod knock, how do you test?
Thought knocking sound was coming from tranny or clutch but now seems more engine related. Seems to get louder with RPM mainly above 2000.
Is there a way to confirm a rod is loose or bearing clearance is too loose?
Old Mar 13, 2013 | 04:50 PM
63mako's Avatar
63mako
St. Jude Donor '08-'09
What is your oil pressure?
Old Mar 13, 2013 | 05:18 PM
gerry72's Avatar
gerry72
You can pull the plug wire from each cylinder until the knock goes away. Creating a dead cylinder takes much of the load off the bearing.
That it occurs only above 2k rpm is a quirk in calling out a rod bearing, though. Normally, it is a load-dependent noise until it becomes really worn. You'd hear it off-idle.
Old Mar 13, 2013 | 06:04 PM
Surfer69's Avatar
Surfer69
Oil pressure is normal, always low when super hot. Undoing plug wire sounds good I'll try that first.
Old Mar 13, 2013 | 09:13 PM
Gale Banks 80''s Avatar
Gale Banks 80'
Remove the Oil Filter, if the Filter head is not full of Metal then cut it open and have a look inside. This will make or break your day.
Old Mar 13, 2013 | 11:01 PM
Indiancreek's Avatar
Indiancreek
Put your timing light on one plug wire then the next. When the light matches the noise you have the bad guy. Drop the pan and see what's going wrong.
Old Mar 14, 2013 | 10:08 AM
Surfer69's Avatar
Surfer69
OK, undid water pump to make sure, still had noise.
Unplugged plugs 1,3,2,4 one at a time still had noise.
So using the screwdriver to the ear trick I listened carefully and it sounds like typical rod knock since I have experienced that noise before. But the odd thing is I put the long screwdriver on the back end of the engine and also heard the noise just as loud as the front. Maybe since everything is steel and tight the noise can travel all over.
So anyway I have my original engine in running order I can swap in a couple days hopefully. It's been sitting 3 or 4 years now but should run. At least I should be able to get to the bottom of all this if noise is gone after swap.
Old Mar 14, 2013 | 01:07 PM
AzMotorhead's Avatar
AzMotorhead
Limping across the line
Usuually
Knocking under acceleration is a Main bearing.
Knocking when decelerating (letting engine slow car) is a rod knock.
Old Mar 14, 2013 | 01:47 PM
hugie82's Avatar
hugie82
Usually cold running knock won't be heard until the engine warms up but if you alway had low oil pressure when hot you were already having problems.
By low I mean 10-15 psi at idle when hot. If you were reading this or lower than the bearing were worn out. Time for a stroker
Old Mar 14, 2013 | 01:58 PM
L88Plus's Avatar
L88Plus
I'd double check the flywheel/clutch/tranny before you tear the engine down. I know that a cracked or loose flexplate sounds like a rod knock, there's enough parts to a clutch/flywheel setup that it's possible that something is making the sound.
Pull your oil filter and cut it open. If you have a bearing gone to the point it's knocking, there should be some bearing material in the filter.
Good luck, hope it's something cheap!
Old Mar 14, 2013 | 02:24 PM
malicatasr's Avatar
malicatasr
Don't forget the fuel pump rod. If you have a lazy fuel pump the rod will bounce around and sound like a engine knock. That's how I got my 2nd 78 Pace Car so cheep the PO thought it was a rod knock and I changed the fuel pump in his driveway and drove away with no knock.
Old Mar 14, 2013 | 03:17 PM
Surfer69's Avatar
Surfer69
Yeah I read about the fuel pump rod and want to rule that out somehow before I pull engine. I replaced fuel pump just 6 months ago but I am finding out these replacement pumps are all junk lately. Maybe I should try another since they are only $30.
Old Mar 14, 2013 | 05:23 PM
Indiancreek
I'd just drop the pan and check the bearings. It costs you a gasket. You can spend a lot of time avoiding the direct route to the most likely cause. It would also give you a good idea what condition your bearings are in.
Old Mar 14, 2013 | 06:29 PM
bpassmore's Avatar
bpassmore
I'd check that flywheel/flexplate, autos are easy to check.
Old Mar 14, 2013 | 09:38 PM
cardo0's Avatar
cardo0
From: Las Vegas - Just stop perpetuating myths please.
Default Check the inspection cover on the bell housing.
Had me fooled. Found the crank flange was hitting a bent corner tip in the sheet metal bell-housing inspection cover. Its definitely worth a look.
cardo0
Old Mar 15, 2013 | 12:03 AM
Gale Banks 80'
OK so what dose that Oil Filter look like????
Old Mar 15, 2013 | 12:14 AM
Scottd's Avatar
Scottd
Fawking Brilliant! Im going to use this trick. Oh wait....I hope I never have to...
To Dreaded rod knock, how do you test?
Old Mar 15, 2013 | 07:25 AM
L88Plus's Avatar
L88Plus
Yeah, and if the knock is double the speed of the light strobe, you'll know it's happening every stroke, not just when that cylinder fires.
Old Mar 15, 2013 | 12:57 PM
hugie82's Avatar
hugie82
I had a fuel pump sound like a rod but it was more like a clanking noise and if you grab the fuel pump, you can really feel it hitting inside the pump.
Old Mar 30, 2013 | 06:18 PM
Surfer69's Avatar
Surfer69
Update: Took two weeks for me to swap engine since I only worked a couple hours here and there. So got old engine running and sure enough no rod knock sound anymore.
So my 383 must have bearing problem. I put new forged pistons in a year and a half ago with new bearings for rods but didnt replace crank bearings. I'll tear it open little by little and report back when I discover what it is.
