73 upper dash pad removal???
Old Mar 13, 2013 | 10:33 PM
go bucks's Avatar
go bucks
Default 73 upper dash pad removal???
Can the upper dash pad be removed and another one be installed without removing the windshield and without damaging the new dash???
Jack
Old Mar 13, 2013 | 11:28 PM
wombvette's Avatar
wombvette
Sure. Remove the side interior trim. Remove the screws holding the dash. Some may be on the underside and you will need a long extension on a 1/4 ratchet. Slightly bow the dash pad up in the middle and remove it.
Old Mar 13, 2013 | 11:29 PM
CA-Legal-Vette's Avatar
CA-Legal-Vette
Yes and maybe
As long as the new dash is a little flexible, warm and you take your time, you shouldn't have any problems. I think that e procedure is spelled out in the tech section on the Willcox web site.
Old Mar 14, 2013 | 08:41 AM
Jud Chapin's Avatar
Jud Chapin
St. Jude 15 Year Donor
St. Jude Donor '11 thru '25
Absolutely. I've done it many times. Just take your time, don't force anything, and put the new dash in the sun to warm it up prior to insulation.
Old Mar 14, 2013 | 01:47 PM
C3 Stroker's Avatar
C3 Stroker
When I installed my new dash and console panels, I found using a heat gun (light setting) made it a very smooth installation. Easy to fit the panels without the danger of cracking them.
Old Mar 15, 2013 | 01:50 PM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
Go Bucks.. step by step instructions can be found at the link below. Click on supporting document.
Willcox
Corvette Dash Pad Remove and Install Instructions 68-77
Old Mar 15, 2013 | 08:54 PM
go bucks's Avatar
go bucks
Thanks to everyone
Old Mar 15, 2013 | 10:57 PM
1974ta's Avatar
1974ta
Default Dash Removal
Make sure to do it on a hot day!
Otherwise even a new one may crack.
Bill
To 73 upper dash pad removal???
