My C-3 Stereo Solution
Old Jun 17, 2002 | 07:16 PM
SlixVett's Avatar
SlixVett
Default My C-3 Stereo Solution
This is how I installed a CD player into my 73. Unfortunately, it will only work with a Phase-Linear PCD-5000 (removed from my 5.0 Mustang). That's the only unit I've found where only half of the face plate removes.
Basically, I mounted the removeable faceplate on the gauge console and ran CAT-5 cable from the connector on the back (soldered on the wires) to the main unit in the jack compartment.
I had to make a connector for the main unit using a piece of printed circuit board; it slips into the existing connector where the faceplate used to fit.
Then I made a new blank faceplate for the main unit to cover the hole.
Factory radio stays in place and I enjoy CD tunes. I didn't want a changer so this seemed like the best method to get some upgraded sound. Put 4X6's in the dash and kick panels and 6X9s in the back.
This method could be adapted to any stereo with a full-size removable faceplate; just mount the faceplate somewhere else. Maybe make a radio delete plate and put the new faceplate over where the factory radio was?
Slick
Old Jun 17, 2002 | 08:30 PM
szercer's Avatar
szercer
Default Re: My C-3 Stereo Solution (SlixVett)
not quite sure how you did that, but it looks really good! :cool:
Old Jun 17, 2002 | 08:31 PM
page62's Avatar
page62
Very slick :yesnod: Whaddya gonna put where the radio used to be???
Old Jun 17, 2002 | 09:06 PM
vettedan's Avatar
vettedan
SlixVett- Very nice! great Job!
Here's my set up.
Old Jun 17, 2002 | 11:27 PM
ddecart's Avatar
ddecart
SPARTAN
CI 3-4-5-6-8-9-10 Vet
CI-9 AutoX Winner
CI-3 Go Kart Champ
St. Jude '03-'04-'05-'06-'07-'08-'09-'10-'11
Default Re: My C-3 Stereo Solution (vettedan)
Nice job both of you. Pretty slick setups.
Dan,
What did you use for a backer plate? It looks so clean, there's no evidence of there ever having been a ****-stereo in there.
Dave
Old Jun 18, 2002 | 12:51 AM
vettedan's Avatar
vettedan
Default Re: My C-3 Stereo Solution (ddecart)
ddecart- I bought the Din adapter from a local auto stereo installer. The Din adapter fills the hole very nicely. Thanks for the complement. BTW, notice where my "high beam" , "e-brake" and "service engine soon" indicators are? Since I don't have the stock speedo or tach anymore I had to find an alternate place to put them. The " service engine soon" indicator was added because of the '95 LT1 installation. The turn signals indicators are above the console gauges.
Dan :cheers:
[Modified by vettedan, 11:18 PM 6/17/2002]
Old Jun 18, 2002 | 01:04 AM
Mike69@ECS's Avatar
0Mike69@ECS
Former Vendor
Cruise-In III Veteran
Cruise-In V Veteran
Sweet intall!!! Both of you guys do great work!
Now who wants to do mine when I pull the interior? Anyone???? :D
Old Jun 18, 2002 | 02:06 AM
Desertdawg's Avatar
Desertdawg
St. Jude Donor '09
VetteDan How do you like the Blaupunkt???
Old Jun 18, 2002 | 02:19 AM
vettedan's Avatar
vettedan
Default Re: My C-3 Stereo Solution (Desertdawg)
Desertdawg-The Blaupunkt works great, no skipping and great reception. My only complaint is the display. At times in certain light, it's hard to read due to the angle it sits at.
Old Jun 18, 2002 | 02:22 AM
Sting Raycin's Avatar
Sting Raycin
Cool idea Slixvett :cool: I love to see somebody using their noodle and coming up with something different. Some of the older Pioneer models also only remove half of the plate.
Jason
Old Jun 18, 2002 | 10:17 AM
Tex71BB's Avatar
Tex71BB
Great idea, Slix. Hey, where'd you get that box that the main part of the stereo is mounted in???? I need one of those.
Old Jun 18, 2002 | 10:58 AM
GrandSportC3's Avatar
GrandSportC3
Cruise-In IV-V-VI-VII-VIII Veteran
St. Jude Donor '03, '06, '17
:cool: setup!!!
:cheers:
Olivier
Old Jun 18, 2002 | 11:05 AM
groovyjay's Avatar
groovyjay
Default Re: My C-3 Stereo Solution (szercer)
:cheers:
Old Jun 18, 2002 | 11:11 AM
Alwyn678's Avatar
Alwyn678
Nice Job :cheers: :cheers:
Old Jun 18, 2002 | 11:15 AM
427V8's Avatar
427V8
C6 the C5 of tomorrow
Looks :cool: too bad it won't work on AC cars :cry:
Old Jun 18, 2002 | 02:42 PM
Todbo's Avatar
Todbo
Default Re: My C-3 Stereo Solution (427V8)
what's meant by only half of the plate? what do I need to look for when I purchase my head unit?
Old Jun 18, 2002 | 02:44 PM
Todbo's Avatar
Todbo
Default Re: My C-3 Stereo Solution (Todbo)
I see what your talking about now , the cd opening stays with the head unit
To My C-3 Stereo Solution
Old Jun 19, 2002 | 01:30 AM
Desertdawg's Avatar
Desertdawg
St. Jude Donor '09
Thanks... :cheers: ... I have been pricing them , this will help :cheers:
Old Jun 19, 2002 | 02:04 PM
Todbo's Avatar
Todbo
slix tells us more about the cat 5 cable and the printed circuit board, where would you get these item's . This is the setup I want. :cool:
Old Jun 19, 2002 | 09:34 PM
SlixVett's Avatar
SlixVett
Default Re: My C-3 Stereo Solution (page62)
Stock radio stays in place.
