Aluminum heads
Old Mar 15, 2013 | 01:52 AM
vetteguy22's Avatar
vetteguy22
Default Aluminum heads
As I was installing my stainless steel headers with stainless steel stage 8 bolt set on my aluminum Dart heads, I began thinking that I should be using anti seize on the bolts so I do not have any problems when I go to remove them some day. Am I correct?
Old Mar 15, 2013 | 01:58 AM
cv67's Avatar
cv67
St. Jude Donor '05
I always use a little when threading into alum esp with stainless hardware.
Use a touch on the spark plugs to to help them find the threads also saved my butt from ruining them a few times.
know that stuff can change torque values (easy to overtorque and not know it).
Old Mar 15, 2013 | 03:17 AM
babbah's Avatar
babbah
Old Mar 15, 2013 | 07:20 AM
L88Plus's Avatar
L88Plus
Stacy on Gearz said that us old farts don't have to remember to buy anti-sieze, Maalox works fine...or was that Milk of Magnesia? Maybe it was Geritol. Or Ex-lax...maybe Preparation H.
I'm sorry, what was the question???
Old Mar 15, 2013 | 08:58 AM
gkull's Avatar
gkull
Is this a small block? Use ARP universal 3/8th 5 point studs and use red lock tight on the head threads.
You will dork the aluminum threads with bolts
Old Mar 15, 2013 | 10:10 AM
harris1507's Avatar
harris1507
I was a Crew Chief on the F-4 and we used Milk of Magnesia on the bolts on the Hi-Temp areas. We also used Anti Sieze on the Brake Bolts (also Hi-Temp). I think it more for the dissimilar metals ( Galvanic corrosion). You can look it up, other wise this would be a long explanation. Have fun, Stay Safe.
Old Mar 15, 2013 | 10:33 AM
SuperBuickGuy's Avatar
SuperBuickGuy
milk of amnesia
Old Mar 15, 2013 | 10:56 AM
REELAV8R's Avatar
REELAV8R
Yes use anti seize. Especially on aluminum heads. Don't forget the plug threads too.
Not familiar with the bolts your taking about, couldn't a guy just use 3/8" threaded stock and cut them to length? Once the studs are in how are you securing the nuts so they don't back off?
Old Mar 16, 2013 | 12:27 PM
gkull's Avatar
gkull
All thread is made out of gauge one pot metal. ARP studs start out at 180,000 psi steel.
I have made carb studs out of grade 8 boltsl
Old Mar 16, 2013 | 01:56 PM
v2racing's Avatar
v2racing
George,
As often as you are swapping and rebuilding your engines, you should be using zippers instead of bolts!
Old Mar 16, 2013 | 02:01 PM
ramair_bryan's Avatar
ramair_bryan
I dorked my heads once............................:leaving :
Old Mar 16, 2013 | 03:40 PM
drwet's Avatar
drwet
And I though L88 was you engine. Now I find out its your age.
Old Mar 16, 2013 | 04:10 PM
diehrd's Avatar
diehrd
I have seen ball cheese used on some things in high heat areas and i am told it works perfectly
Old Mar 16, 2013 | 04:59 PM
Crepitus's Avatar
Crepitus
carefull! hot or sharp surfaces could damage sensitive tissue
To Aluminum heads
