Power feed for cameras
Old Mar 15, 2013 | 08:58 PM
San Diego Ron's Avatar
San Diego Ron
Default Power feed for cameras
Wanting to install front and rear cameras and monitor on my '77 Stingray but don't know best place to pick up + and ground inside car. Plan on using on/off/on switch and in-line fuses ( don't care to hook up to reverse lighting). Should I hook into fuse block or look for another switched hot wire or go straight off battery? Thanks, and no I'm not crazy it is just that my wife wants to drive car and she has no clue as to where the front of car ends and I don't want her coming home with a busted nose. I'm sure I can get it to work but I would like to do it the right way and not butcher it up. Plan on using clip on or suction cup for monitor so it can be un-pluged and put away when not needed.... (she gets tired of driving the thing and goes back to her Smart car).
Old Mar 16, 2013 | 01:05 PM
San Diego Ron
No response...guess this is just too silly a question to be asking in Tech. or maybe wanting to put cameras on car is just too stupid of an idea, either way the cameras are going on car so would it have helped if I had asked where to pick-up hot lead to add accessories inside car?
Old Mar 16, 2013 | 01:40 PM
donnie1956's Avatar
donnie1956
There is an accessory terminal in the fuse block. Its hot with key on.
Learning_Curve's Avatar
Learning_Curve
If you can get under the dash and see the fuse block, there may be an empty slot labeled ACC for accessory. Should be a switched ignition circuit.
Old Mar 16, 2013 | 03:34 PM
San Diego Ron
Perfect, and thanks so much for answering. I do have empty acc slot on fuse panel...I would probably have tied into cigar lighter without being set straight.
Old Mar 16, 2013 | 04:31 PM
donnie1956's Avatar
donnie1956
That would have been hot all the time and drained the battery.
Old Mar 17, 2013 | 07:34 PM
San Diego Ron
Today I made a bracket to hold front camera...not so bad.
Old Mar 17, 2013 | 07:42 PM
CherokeeWarrior's Avatar
CherokeeWarrior
It is smaller than i was expecting and blends in pretty well so it is not obvious. Good job!
Old Mar 17, 2013 | 08:57 PM
donnie1956's Avatar
donnie1956
Where are you mounting the screen?
Old Mar 18, 2013 | 09:30 AM
San Diego Ron
I'll let you know as soon as I figure that part out...thinking on left side between ashtray and radio with suction cup.
Old Mar 18, 2013 | 06:52 PM
San Diego Ron
Today added camera to rear...hardest part was running wires, got them up to kick panel so maybe tomorrow I'll be able to finish this up. Still don't know where I'll place monitor.
Old Mar 19, 2013 | 08:00 PM
San Diego Ron
Working today...not me I'm retired, cameras are hooked up.
Old Mar 20, 2013 | 08:09 AM
donnie1956's Avatar
donnie1956
What are the switches for?
Old Mar 20, 2013 | 09:05 AM
TimberwolfFXDL's Avatar
TimberwolfFXDL
BMW license plate?
Old Mar 20, 2013 | 10:32 AM
MAXCO's Avatar
MAXCO
Probably to switch from front/rear camera feed.
Old Mar 20, 2013 | 11:46 AM
San Diego Ron
Right...ON / OFF/ ON Switch, Front camera, off, rear camera. BMW thing came with car, probably get changed to something else down the road. Best thing about this project was that it got me looking around at wiring and discovered a cut off switch had been installed by someone using speaker wire (or something similar) that was accident sure to happen...insulation was being melted away and could have caused fire.
Old Mar 20, 2013 | 12:08 PM
Oldguard 7's Avatar
Oldguard 7
Interesting. Maybe the camera could see if someone was attempting to steal your vehicle.
Old Mar 21, 2013 | 02:03 PM
San Diego Ron
Not trying to keep post alive but wanted to show what could have burnt my car into puddle of rubber and plastic. This was connected to hot wire to distributor and ran to under driver's seat and back....using speaker wire!
To Power feed for cameras
