Ground Screw to Core Support Small Block
Old Mar 16, 2013 | 11:27 PM
paragonspirit's Avatar
paragonspirit
Default Ground Screw to Core Support Small Block
1975 Auto with Air.
Does anyone have handy the screw that holds the ground in this image?
http://i494.photobucket.com/albums/r...on/ground9.jpg
I didn't have enough left of the core support I removed to rescue that (and intermittent (usually) bad headlights are now explained).
Since I don't have the old one, I can't find a new one, can someone obtain for me a length / threadcount / diameter so I can stop by the Fastenal shop next week?
I have the same question for the screw / post holding the center of the A/C Condensor to the front of the radiator core support, but can't find a picture of it. This one wears a little rubber grommet that I have managed to get (thanks Willcox!), but nobody had the screw...
SS
Old Mar 17, 2013 | 08:06 AM
dembo's Avatar
dembo
Glad to see my pictures being used. Unfortunately I can't help you with the screw size. I used what I had left of self threading screws which fit the terminal hole. It was a coarse thread and maybe 1/2" long.
Srry
Nick
Old Mar 17, 2013 | 09:46 AM
Alan 71's Avatar
Alan 71
Hi ps,
Here a picture of the screw from my 71.
Often ground connections have a star washer, but in this case there isn't one.
I'd call the bolt 3/16" diameter.
Regards,
Alan
Old Mar 17, 2013 | 10:18 AM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
Ok.. posting in here as a reminder.. tomorrow I'll take a look in the shop and see if I have a few of these. No guarantee.. but a good chance...
Old Mar 17, 2013 | 12:56 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
It's a sheet metal screw, course thread. Look for something large enough to fit the harness and the hole in the support. Try 1/4" 14 x 1/2".
Old Mar 17, 2013 | 09:49 PM
paragonspirit
Nick - Thanks for having the post with all the great pictures of grounds, they were invaluable, I've referenced that thread a few times!
Alan - Great shots, that gives me a good starting place for a Fastenal or Cheapo-Depot run if Willcox doesn't have any around there. You don't have access to the A/C Condensor bolt/screw do you the one with the rubber grommet as vibration damper at the bottom center of the core support?
Easy Mike - Believe me, I went through every box of screws in the house, workshop, and garage, the only one that was close was long enough to punch a hole through the backside of the radiator too!
Ss
Old Mar 18, 2013 | 08:09 AM
Alan 71's Avatar
Alan 71
Hi ss,
Sorry, no a/c part info or pictures.
Regards,
Alan
Old Mar 18, 2013 | 09:59 AM
Easy Mike's Avatar
Easy Mike
Originally Posted by paragonspirit
Easy Mike - Believe me, I went through every box of screws in the house, workshop, and garage, the only one that was close was long enough to punch a hole through the backside of the radiator too!...
Hop down to any well stocked hardware store and find a shorter one in open stock. Half of the gotta have little things on my 68 came from my True Value Hardware Store.
Old Mar 18, 2013 | 12:50 PM
0Willcox Corvette
Former Vendor
Ok.. I did some research on this this morning. I have 1 I removed from a 79 core support this morning. It looks the same but oddly enough I had to use a 10mm to pull it out so my guess is the one I have is from a later car like a 79 - 82. So at some point GM changed this.
On 1975 The lower condenser bolts were just a standard looking bolt and used a flat washer between it and the grommet.
The lower bolts, 9420065 came up on a google search at this link.. I'm sure you can get these cheaper if you look hard enough. http://www.amkproducts.com part number b-12108
The Smaller bolt used to bolt the strap to the condenser was 3027371 was hex 10-32 and used by all kinds of GM cars up till around 1981. I found no other info on this bolt yet.
So far this is what I found on the upper bolts from the 1972 gm parts book.
The right upper was p/n 180086 BOLT (5/16-18 x 1 5/8)
The left upper was p/n 180084 BOLT (5/16-18 X 1 1/4)
Still working on that ground bolt.. in standard.
Old Mar 19, 2013 | 09:20 PM
0Willcox Corvette
Former Vendor
Update: I've found the ground screw and have added them in a kit to our site tonight.
http://willcoxcorvette.com/product_i...ducts_id=27675
Willcox
To Ground Screw to Core Support Small Block
