Fuel Sending Unit Removal Tool
Old Mar 20, 2013 | 03:28 PM
Brcmpbl's Avatar
Brcmpbl
Default Fuel Sending Unit Removal Tool
So when I get to replacing my fuel sending unit here in a few weeks on the 70 (unit is on the bottom) do I actually need the fancy sending unit removal tool, or is there a sure fire way to get the thing out with something else? Thanks.
Old Mar 20, 2013 | 04:08 PM
Roco71's Avatar
Roco71
A few years ago I bought a new tank and sending unit and did not use the tool to install mine.
moonsteel's Avatar
moonsteel
Holley HP EFI w/TPI
I have a 1974 should be close to the same, I used a screwdriver and hammer
Old Mar 20, 2013 | 04:13 PM
Garys 68's Avatar
Garys 68
Hammertime...and a chisel, no problems. Do you a new O ring and maybe a little oil on reimstalling. You can damage the old one removing it, and they're cheap.
Old Mar 20, 2013 | 04:22 PM
Jeff_Keryk's Avatar
Jeff_Keryk
Additionally, when I changed my tank, I used the old steel cover, as the new one was crap.
Old Mar 20, 2013 | 04:31 PM
Brcmpbl's Avatar
Brcmpbl
Thanks guys. I have a whole kit for the install, gasket and all that jazz.
Jeff, not surprising...repro parts can be so disappointing these days. I'll have a good look at the cover my new one came with.
Old Mar 20, 2013 | 04:49 PM
Alan 71's Avatar
Alan 71
Hi B,
I agree that a screw-driver and small hammer does the job.
Before you take the existing one off, take a CLOSE look at how far the 'seating ramps' need to be turned before they hit the 'stops'.
It's possible to think you have the new one turned all the way on, but if it's not at the 'stops' you may have a slow leak.
Regards,
Alan
Old Mar 21, 2013 | 02:28 AM
my 76 ray's Avatar
my 76 ray
Originally Posted by Alan 71
Hi B,
Regards,
Alan
There was a thread not too long ago about that very issue, however the leak was anything but slow.
To Fuel Sending Unit Removal Tool
