Cam, CR, compression testing lbs
Old Mar 20, 2013 | 07:48 PM
calwldlife's Avatar
calwldlife
St. Jude Donor '22
Default Cam, CR, compression testing lbs
Curious how a 10 to 1 motor will give 210 220 lbs
of pressure on a guage.
14.7 lbs of atmos so, 10 (14.7) to 1 =147 lbs?
Old Mar 20, 2013 | 08:48 PM
63mako's Avatar
63mako
St. Jude Donor '08-'09
A 10 to 1 motor could show #140 or #220. It all depends on the cam specs specifically intake valve closing point. A 10 to 1 engine that has a compression test of #220 likely won't run on pump gas.
Old Mar 20, 2013 | 11:07 PM
cv67's Avatar
cv67
St. Jude Donor '05
Old Mar 21, 2013 | 12:55 AM
larrywalk's Avatar
larrywalk
Veteran: Marine Corps
The compression process is nearly adiabatic, which means that ideally no heat is lost... When the piston rises, the rising compression also causes the temperature to rise which further increases the pressure seen on the gauge. I'm not going to try to run through the thermodynamic equations (been a long time ago), but the peak pressure will be a lot higher than a simple ratio of pressures. And, of course, as Mako commented, the gauge values are greatly affected by when the intake valve closes with a later closing (as in a big cam) decreasing the value seen on the gauge.
Old Mar 21, 2013 | 01:23 AM
calwldlife's Avatar
calwldlife
St. Jude Donor '22
built a 302 ford
10.5 to 1
210 lbs
282 duration, 480 lift, 113 lobe, polished iron heads.
took some effort to jet the carb and curve the dist.
did similar with a couple LT1s
1st a flat tappet one then a roller.
all done years ago before the interwebs and info about cam science.
after reading the dyn CR threads, made me wonder about
cyl pressures and what if any the ideal pressures would be.
Old Mar 21, 2013 | 10:35 PM
cardo0's Avatar
cardo0
From: Las Vegas - Just stop perpetuating myths please.
Default Wrong science.
1 atmosphere = 14.7 lbs/in2 at standard temp (68*F) and at standard density (0.0765 lb/cu ft). Gauge press is press above/greater than atmospheric press. Compression ratio is change in volume meaning if static volume at TDC = say 4.27 cubic inches (or 70cc) then swept volume plus static volume for 10 to 1 is 42.7in3 (700cc). Pressure follows the ideal gas law: PV=nRT where P = press, V = volume, n = amount of substance in moles, R = gas constant, T = temp.
Compression test should be done with engine warm or hot (good luck removing the plugs hot) to maximize ring seal. Per D. Vizard for a good performance engine should be close to 200 psi (gauge press) and no less than 180psi. Max press for street engine should be <220psi.
Good luck cal,
cardo0
Old Mar 21, 2013 | 10:41 PM
calwldlife's Avatar
calwldlife
St. Jude Donor '22
Good luck cal,
cardo0
Old Mar 21, 2013 | 11:27 PM
63mako's Avatar
63mako
You are not just compressing air. It has gasoline mixed in. Liquids don't compress. As I said #220 likely won't run on pump gas. Might if everything is perfect. Quench, Al heads, Fast burn chamber design, A/F ratio, Cool thermostat, CAI, Right timing curve, Ect.
To Cam, CR, compression testing lbs
