76 corvette turbo???
Old Mar 21, 2013 | 11:39 AM
Cody's Corvette's Avatar
Cody's Corvette
Default 76 corvette turbo???
Should I put air research turbo on my
76 corvette, 305, auto
Old Mar 21, 2013 | 12:03 PM
7t9l82's Avatar
7t9l82
a 305? dont waste your time
Learning_Curve's Avatar
Learning_Curve
Can you weld and shape metal? There are no bolt in kits to turbocharge a C3. If you haven't done so yet, read this post. http://forums.corvetteforum.com/c3-g...d-build-4.html
I would guess by the time you add up the price of everything you would need to make the swap, you could replace your 305 with a 383 crate motor.
Now if you want a challenge, I say go for it. 383's are a dime a dozen around here. You may get be able to get a single turbo manifold kit from ebay and mod it to fit.
Old Mar 22, 2013 | 05:06 AM
Sixxshot87's Avatar
Sixxshot87
5th Gear
If your talking about ANY blow through carb setup or any turbo app with a carb don't waste your time. If you want at least 2x gas milage at least 2x power and at least half the emissions go LS.
Old Mar 22, 2013 | 09:58 AM
SuperBuickGuy's Avatar
SuperBuickGuy
Yes, turbo is good!
Old Mar 22, 2013 | 10:40 AM
SH-60B's Avatar
SH-60B
Turbo a 383.
To 76 corvette turbo???
