I know that I should be smart enough to figure this out - but then again, maybe not! What is the easiest way (if there is such a thing) to replace a turn signal indicator light on a 78 Vette. Tried going under the console, but I'm old and large and that just didn't work. Thought about pulling the guage cluster, but when I took the cover off - it didn't seem to want to come out. Any help will be greatly appreciated. :confused:
I'm old to, but I got under there and just stuck my hand in and was able to pull the connector and replace the bulb. Some other alternatives I considered where to remove the drivers seat for better access or remove the console( you have to drop the steering column- :U ) or remove the dash and try to reach down from the top.
There is no easy way for us old and in my case plump guys to get to the bulb.
