82 temp sensor leaking
Old Mar 21, 2013 | 09:45 PM
alconk's Avatar
alconk
Default 82 temp sensor leaking
I just recently installed my ported intake on my 82 and after a few drives I noticed a small puddle of antifreeze coming from under my temp sensor that screws in the front of the intake. When installed I did NOT use any sealer or tape for the threads as it grounds through that process but am scared to tighten it any more as I could crack the intake. That's what I did to my last intake and had to use JB Weld to fix it. That's not what I want to do. Maybe there is a torque spec????
Old Mar 21, 2013 | 09:49 PM
calwldlife's Avatar
calwldlife
St. Jude Donor '22
not true, new ones come coated in sealer.
Old Mar 21, 2013 | 10:34 PM
alconk's Avatar
alconk
Thanks, that's what I was read. Got it from the internet, everything is true on there.
Old Mar 21, 2013 | 10:39 PM
calwldlife's Avatar
calwldlife
St. Jude Donor '22
it is a resistor.
2 wires
1 wire 5v computer signal in
(hot) 2 wire out to computer 5v
(cold) 2 wire out to computer not 5v
basically
Old Mar 21, 2013 | 10:41 PM
alconk's Avatar
alconk
it is a resistor.
2 wires
basically
Wow.. impressive.. Thank you. So are you saying I can put thread sealler on it or buy one that has it from the maker?
Old Mar 21, 2013 | 10:44 PM
calwldlife's Avatar
calwldlife
St. Jude Donor '22
yup
Old Mar 21, 2013 | 10:45 PM
alconk's Avatar
alconk
yup
Great!! will do.
To 82 temp sensor leaking
