I've used the 0.015 Fel-pro lots of times, stick with them as they do bump your CR up.
All I can suggest is to clean up the mating surfaces really well, reuse the gaskets if they're not damaged, bolt one back on with lots of thread sealer in the holes and on the treads and torque down 10ft lbs more than suggested.
Let the sealer go off before you spin the engine over
Then do a compression test.
I've only ever used ARP bolts so i'm not sure how reusable stock bolts are?
I used the 7733 gasket with coppercoat. I wonder if the 1094 would have been the better choice and not use the copper coat? IDK. Anyone have a part number recommendation for using the vortec heads on this 880 block?
BTW... pics of my oil leak mentioned way earlier in this thread:
Not sure what copper coat is? Similar to copper ease I guess?
And no, don't use that
And I presume you're using the washers with the head bolts?
I just had to go back and look. These are the bolts I bought: http://www.ebay.com/itm/390414103936...84.m1497.l2649
But I don't think they came with the washers. I remember when assembling it that maybe they were talking about the head studs/nuts needing washers since these had a washered head. Well, there's another thing to add to my shopping list this time.
Vortec heads and intakes do not have the water passages that all other SBC heads have. You must run a coolant line from the intake manifold to the water pump or it will build up steam and not allow water to circulate in the top end. This can be kind of hard on gaskets and stuff. This is a problem that most Corvettes already have, but made much worse with the vortec setup. Easy to fix, and we'll worth the effort to use the vortec stuff.
Interesting, i'm not familiar with Vorvtec stuff although i've read a lot about it. The heads are mean't to be great.
I thought I had read this before, but when it came time to confirm and do the build, I couldn't find anything.
Is there a link to an article where I can read up on it?
I will add that to the list of things to do. I was informed (incorrectly apparently) that the extra hole on the passenger side water pump flange was for coolant bypass...
Here is what I did, it does not look great (Steam Punk?) but it should work, and cost under twenty dollars. The black threaded thing is just a plug in my fuel line. The hose is run to a fitting you can just see, under it.
I am thinking I will run it from the top of the water pump to that port ont he front of the intake in the picture above.
Having a hell of a time trying to find the part number for a set of ARP washers that are the right size for these bolts. I used the 134-3601 bolts... if I knew what washers came with them I can order a replacement set. Kinda wondering if this might be a big contributor to my problem. If I ran out of thread (hit a shoulder) in the hole I could theoretically still hit torque spec without having a good clamp.
Maybe? My local speed shop sells the washers separately, they should have come with the kit surely? They are mainly for ali heads to stop galling but I use them on steel heads too.
I have no way to tell if they are right? They sell several different inner and outer diameters. If I could find out what originally was supposed to be included then I'd know what to order
I emailed both ARP and the KMJ Performace seller from ebay. Maybe one of them can help.
About to order my head gaskets. Just deciding if there's anything else I want to get coming at the same time
I just got one from the garage, measures just under 13/16" or 20mm outside and 11.5mm inside or just over 7/16".
Do you have decent intake gaskets? 'the right stuff' sealer, thread lock etc?
I have these gaskets... wondering if I can reuse them since they are multi layer rubber/steel and were only ran in a torqued state for few minutes. Doubt they took a set that quick.
