Cracked rotor
Old Mar 24, 2013 | 04:22 PM
qwank's Avatar
qwank
Originally Posted by diehrd
Someone mentioned it looks drilled ? I do not see any tool marks in the photo to see a drill was used.
30 years of rust will do that lol
Old Mar 24, 2013 | 06:55 PM
lionelhutz's Avatar
lionelhutz
Honestly, the rotor looks way past its service life. That rotor was either cut or broken to cause the missing fin piece and it looks like it's under the minimum thickness so it's not a big surprise it cracked there. The rotor looking about evenly worn on both sides indicates the caliper is OK. Checking that the pads are about equally worn on both sides of the rotor would also tell you the caliper is OK.
Old Mar 24, 2013 | 11:20 PM
cwaynem's Avatar
cwaynem
Just ordered new rotors and pads for both sides. When I take off the calipers I will check the pad wear before I replace them - good idea.
I don't know whether it was the rotor or the differential or maybe even both making the noise. It prompted me to take it to tracdogg2 (Mike) to check out. At least I know the differential (and now the rotors) will be good when I am done.
Old Mar 24, 2013 | 11:31 PM
mds3013's Avatar
mds3013
Lucas TX. OK, I see where that is. We are lucky to live close to Mike. mike...
Old Mar 25, 2013 | 11:58 AM
tracdogg2's Avatar
tracdogg2
Originally Posted by qwank
it's possible the factory drilled that spot out to balance the rotor. I actually have a weight installed in my right front rotor from the factory (still riveted onto the hub)
You are the closest to being correct. That was done for balancing. But that is where they added metal, usually heavy tubing. It has long since fallen out. Most likely at one time the rotor was overheated.
Mike
Old Mar 25, 2013 | 10:53 PM
7t9l82's Avatar
7t9l82
about 25 years ago i came across the same thing. it was caused by a "mechanic" with a 10 pound hammer and not knowing the parking brake was set and the rotor was riveted on.
Old Mar 25, 2013 | 11:12 PM
Ironcross's Avatar
Ironcross
Over time rust has eaten the vanes between the rotor surfacers...might as caution inspect the others
Old Mar 26, 2013 | 02:20 AM
AngelDolly's Avatar
AngelDolly
6th Gear
I think you must consult the company..They will better resolve the problem with original spear parts!
Angel Grinder
Old Mar 26, 2013 | 07:44 AM
qwank's Avatar
qwank
Mike
that's what the weight in mine is, metal tubing. i'll have to check the area on mine for cracks since the wheels are off right now
Old Mar 26, 2013 | 07:46 AM
bpassmore's Avatar
bpassmore
Is it a color photo glitch? The crack looks "fresh", with no "rust tracks" from the area and no unusual wear marks in the area of the crack. There should be evidence of a slight uneven wear pattern at the site caused by the force causing the "bump" noise.
Old Mar 26, 2013 | 10:21 AM
qwank's Avatar
qwank
here's a picture of my metal tubing weight. My rotor was not drilled to fit it in though:
