71 conv speedometer cable replacement.
Old Mar 28, 2013 | 05:01 PM
Roadster71's Avatar
Roadster71
Default 71 conv speedometer cable replacement.
I'm in the process of installing a kiesler rs500 trans and have to swap out the cable for the new trans.
How do you get at the speedometer to disconnect the cable? I tried from under the dash and then dropped the steering wheel and pulled the cluster out as far as I could. Still can't get my hand in there. Any suggestions or past experience to be shared?
Pulling the engine/trans was easier than this.
Old Mar 28, 2013 | 09:29 PM
robert.sperry's Avatar
robert.sperry
I recommend you remove the dash pad. It will still be tight but doable especially if you have already moved the instrument panel back.
Old Mar 29, 2013 | 08:52 AM
redrdstr72's Avatar
redrdstr72
I just replaced my tach cable and did it this way with 100% success. To remove the upper dash pad, you'll first need to remove the A pillar trim, the sun visors and the header trim. BE CAREFUL when removing the dash pad. I was able to remove mine by unscrewing all fasteners (screws) and then pushing the LH side/end forward, while CAREFULLY "bowing" the pad just enough to allow the pad's RH side to clear the A pillar when pulling out. If you bow it too much, it'll break. This will cost you about $300 and a lot of
Old Mar 30, 2013 | 06:07 PM
Roadster71's Avatar
Roadster71
Thanks for the responses. I removed the dash pad and was able to disconnect the old cable. I ran the new one but haven't had the opportunity to try and connect it. Won't be easy I can only get two fingers in there.
I have a bigger problem now, the top of the 5 speed is hitting the tunnel and have to come up with some way to get more clearance.
Old Mar 30, 2013 | 06:24 PM
Alan 71's Avatar
Alan 71
Hi r71,
Connecting the new cable is easier since it just needs to be pushed into place and the clip catches it automatically.
You'll here a click as you push it in.
Regards,
Alan
Old Mar 30, 2013 | 09:20 PM
redrdstr72's Avatar
redrdstr72
Originally Posted by Alan 71
Hi r71,
Regards,
Alan
Reinforcing what Alan says, plus adding that it might be a good idea to "pull" a bit on the cable after connecting it. This will ensure that the spring clamp has gotten a firm hold of the cable's flared end. I'd hate to have you re-assemble only to find that the spring clamp wasn't fully engaged and the !@#$ thing fell out.
Good luck with this project, AND the new one too!
Old Mar 31, 2013 | 08:44 AM
Roadster71's Avatar
Roadster71
Thanks....hopefully I'll have a opportunity today to give it a try.
To 71 conv speedometer cable replacement.
