TIMING CHAIN TIME...I THINK???
Old Jun 20, 2002 | 12:38 AM
jyounane's Avatar
jyounane
Default Re: TIMING CHAIN TIME...I THINK??? (Ben Taylor)
Ben,
I had 58000 miles on mine......no warnings......There were some nylon bits in the sump, but I don't recall seeing any during oil changes.
Best regards,
Joe
69 427L36 M21 3.08 White Coupe
Old Jun 20, 2002 | 07:41 AM
OkeeGuy's Avatar
OkeeGuy
aprox 122,000 miles but the engine has been rebuilt...dont know when...
i suspect this cause the block numbers match but it has 305 heads on it and runs awesome...smooth, no unwanted sounds and dosnt smoke or use oil...
i think some idiot said "this chain and gear dont look too bad, think i'll reuse them" :rolleyes:
Old Jun 20, 2002 | 08:00 AM
Mikes80L48's Avatar
Mikes80L48
More likely it's your harmonic balancer coming apart, but you might as well replace your timing chain and water pump while you're at it. A double roller chain will probably not fit in your engine, but you can always buy it and see, then return it if it doesn't fit.
A double roller timing chain fit on my dad's 80 L48 with no problem.
Old Jun 20, 2002 | 08:06 AM
OkeeGuy's Avatar
OkeeGuy
Default Re: TIMING CHAIN TIME...I THINK??? (Mikes80L48)
fit on my L-82...no problem too:)
Old Jun 20, 2002 | 09:13 AM
BB wowbagger's Avatar
BB wowbagger
Default Re: TIMING CHAIN TIME...I THINK??? (SIGNGUY)
Now its the perfect time to get a GearDrive..You will love the song from those... :cheers:
Old Jun 20, 2002 | 10:02 AM
427V8's Avatar
427V8
C6 the C5 of tomorrow
Default Re: TIMING CHAIN TIME...I THINK??? (BB wowbagger)
:U
Is he building a Drag car or a street car??
Gear drives are just wrong for a street car.
Old Jun 20, 2002 | 10:06 AM
BB wowbagger
Default Re: TIMING CHAIN TIME...I THINK??? (427V8)
Why are geardrives "wrong" for a street car? :confused: :cheers:
Old Jun 20, 2002 | 12:05 PM
Kingt's Avatar
Kingt
Wow, nice gear!
