Ignition switch lock position
Old Mar 30, 2013 | 04:46 PM
redwhitekat's Avatar
redwhitekat
Default Ignition switch lock position
Ok some help needed. As I remember to lock the ignition switch with the key inside I used to have to put the transmission in the reverse gear right ??
My problem is my ignition switch is not turning all the way back to that little notch position that says lock even with tranny in reverse or any other gear
Old Mar 30, 2013 | 05:10 PM
Alan 71's Avatar
Alan 71
Hi rwk,
Check that when in reverse the cable is moving the lever on the steering column as far UP as it can go.
Regards,
Alan
Old Mar 30, 2013 | 05:19 PM
redwhitekat
Ok so it does have to be in reverse to lock ???
Old Mar 30, 2013 | 07:32 PM
redwhitekat
Where is that lever and how can I acess it
Old Mar 30, 2013 | 07:55 PM
redwhitekat
Ok I see it on the aim page 322 I guess I have to remove the console. I wonder why they only designed it to lock in reverse would it do any harm if I just bypass this
Old Mar 31, 2013 | 08:40 AM
Jim Shea's Avatar
Jim Shea
Open the hood. It is right under the brake master cylinder.
Jim
Old Mar 31, 2013 | 11:12 AM
redwhitekat
Ok I found it disconnected cable at the switch lock mechanism works fine now. Thanks a bunch guys
To Ignition switch lock position
