75 shifter console reinstall
Old Mar 31, 2013 | 01:34 PM
My 75 Convertible's Avatar
My 75 Convertible
1st Gear
Default 75 shifter console reinstall
How does one get to the two nuts under the gauge bezel to tighten and draw up the shifter console. I cannot get my hands in there, nor a wrench.
Old Mar 31, 2013 | 02:04 PM
ignatz's Avatar
ignatz
This had to have been the crappiest job on the assembly line. I had to put my cluster in and out many times and decided to make some mods. Put an extension on the bolts. An allen head bolt with a nut threaded on. That way the nut can never fall off.
Looking from the backside on the workbench, this bolts to a bracket I pop riveted to the console.
Missing from the second picture are two slots I cut into the bracket so the extended bolts will slide into the bracket when you assemble it in the car.
I think there are numerous posts on the subject. This is my solution, its still not easy but feasible.
Old Mar 31, 2013 | 02:09 PM
ignatz's Avatar
ignatz
Addendum: Also missing from that picture are the nuts and washers that actually tighten the two units. That picture was from a trial fit, don't have a final picture. You can spin the nut by hand in the car to get a bit of a grip and then reach in to tighten things with a wrench.
Old Mar 31, 2013 | 02:21 PM
MrJlr's Avatar
MrJlr
Left mine off......can't even tell.
Old Mar 31, 2013 | 03:27 PM
dembo's Avatar
dembo
Mini ratchet (hand palm size) worked for me
Old Apr 1, 2013 | 09:44 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
1/4" drive with a swivel head socket. You also have to hold your tongue in exactly the correct spot.
Old Apr 1, 2013 | 10:08 AM
Roco71's Avatar
Roco71
If you think its hard getting them on wait until you have to get them off.
To 75 shifter console reinstall
