Too Low?
Old Apr 4, 2013 | 11:09 AM
qwank's Avatar
qwank
Originally Posted by 7t9l82
its not supposed to look like a four wheel drive either. with a a more modern wheel and tire package it would look killer.
It's funny how smaller wheels look better with more gap, but larger wheels look better with less
Old Apr 4, 2013 | 12:12 PM
DucatiDon's Avatar
DucatiDon
C2 of Year Finalist (performance mods) 2019
2018 C2 of Year Finalist
Here is part of my problem....
This is the spring side that sits higher. See the spring end is just shy of the end of the spring pocket. This side also I noticed the spring is very close to the frame.
Here is the lower end....180 from the end of the spring pocket.
This is the low side. The spring is 180 out from the end of the pocket at top, but the bottom is dead on. (hard to see in this pic)
Im going to rotate the low spring 180 and seat the the top end on both sides and see where I end up.
Old Apr 4, 2013 | 12:20 PM
Shark Racer's Avatar
Shark Racer
I think that little inspection hole in the first picture is where you're supposed to aim the coil. Get the end of the coil about halfway in there, and let the bottom fall whereever it does.
Old Apr 4, 2013 | 01:25 PM
tsw71's Avatar
tsw71
Old Apr 4, 2013 | 04:13 PM
DucatiDon's Avatar
DucatiDon
OK...re-seated both springs correctly in the upper pocket. No change in ride height.
26" to fender driver side, 27" on passenger side. At least I know they are installed correctly.
Alignment tomorrow.
In retrospect, I think the 550lb springs would have been fine without being cut.
If it wears on me, Ill do the springs again. cheap.
I really like the look of the factory aluminum wheels, but I wouldnt pass up the right set of 17"/18"s....
Just havent found the "right" wheel for this car yet.......
Old Apr 4, 2013 | 05:21 PM
Shark Racer
Owning another pace car, I've been in your boat for at least 10 years now...
Old Apr 4, 2013 | 06:16 PM
DucatiDon's Avatar
DucatiDon
After some fiddling, Ive come to the conclusion that the car wasnt straight to begin with.
Im at 26.5" driver side front to mid wheel well.
27.25 Pass side front
27.5 driver rear and
28.0 pass rear. At least its consistent 1" difference.
With 8" bolts I cant really lower the pass rear any lower.
Old Apr 4, 2013 | 06:45 PM
Shark Racer
One side is usually higher than the other and I think it's the passenger side. What's the distance to the frame right behind each wheel?
Old Apr 4, 2013 | 07:26 PM
DucatiDon's Avatar
DucatiDon
Looks like 8.75 on Driver side and 9.0 on pass side.....
Old Apr 4, 2013 | 08:25 PM
Shark Racer
1/4" ain't bad... party on!
Old Apr 7, 2013 | 07:42 AM
DucatiDon's Avatar
DucatiDon
Alignment done to VBPs advanced Street specs. Ready to Rumble....
