Too Low?
Old Apr 2, 2013 | 04:12 PM
DucatiDon's Avatar
DucatiDon
C2 of Year Finalist (performance mods) 2019
2018 C2 of Year Finalist
Default Too Low?
550 springs with 1/2 coil cut....
This is with Aluminum Heads.....
before:
After:
I think Ill try 8" rear bolts......
And with 7" rear spring bolts....
Old Apr 2, 2013 | 04:19 PM
HOOAH's Avatar
HOOAH
1969/1971/2021 Coupes
St. Jude Donor '09-'10-'11-'12-'13-'14-'15
Damn, that's with only 1/2 a coil removed? Seems that the difference shouldn't be that noticeable. Is there any rubbing issues when turning from stop to stop (left to right)?
May be a tad too low but I still like it. Do you like it? In the end, that's what counts.
Terry
Old Apr 2, 2013 | 04:21 PM
MelWff's Avatar
MelWff
were you able to align it to specifications?
Old Apr 2, 2013 | 04:22 PM
DucatiDon's Avatar
DucatiDon
I think the 550 didnt need to be cut.....But Im not gonna do the job again! It will be fine...Ill lower the rear an inch to compensate.
And anyone who tells you it aint a one man job...isnt lying. But I managed anyway.
Old Apr 2, 2013 | 04:23 PM
DucatiDon's Avatar
DucatiDon
Goes in for alignment Friday. I expect to be able to get close, but not perfect specs without offset control arms.
Old Apr 2, 2013 | 05:42 PM
dc502's Avatar
dc502
I like it
but then mine sits low like that too. watch out for the speed bumps they are a vette killer when low like that.
Old Apr 2, 2013 | 09:51 PM
gcusmano74's Avatar
gcusmano74
How much daylight do you have between the lower control arm bumpstop and the frame? If you look at the Chevy Power book, they say you can remove a small amount off the tip of the rubber bumpstop to allow a bit of suspension travel on a lowered car..
Old Apr 2, 2013 | 09:58 PM
Shark Racer's Avatar
Shark Racer
I like it. My 78 with iron heads and all the trimmings looked about like your 1/2 coil removed pic. Once I put alum heads on it looks pretty much the same as your "before".
With alum heads:
Can dig up a picture of the "before" if someone's interested.
Old Apr 2, 2013 | 10:44 PM
3JsVette's Avatar
3JsVette
If you can lower the back to match and you're OK with it you're good to go.
Old Apr 3, 2013 | 12:20 AM
SuperBuickGuy's Avatar
SuperBuickGuy
are the lower control arms parallel with the ground?
Old Apr 3, 2013 | 09:23 AM
qwank's Avatar
qwank
Looks similar to mine. I was worried at first, but I think it's going to be ok.
Old Apr 3, 2013 | 09:34 AM
DucatiDon's Avatar
DucatiDon
The driver side seems to be about 3/4" lower than the passenger side ....I wonder if the pass side spring didnt seat properly. Is there something that would cause it to sit too low? If both springs are in the pockets, what would cause a 3/4" difference?
Old Apr 3, 2013 | 09:35 AM
7t9l82's Avatar
7t9l82
looks fine to me, need to do mine.
Old Apr 3, 2013 | 10:09 AM
SuperBuickGuy
what you guessed - spring not in its pocket, however, a brief drive should get it to where it belongs.
Old Apr 3, 2013 | 11:32 AM
qwank's Avatar
qwank
My passenger side was slightly lower also, after I test drove it and properly torque the control arms while the vehicles weight was on them.
what I did was measure the frame to ground clearance and found that it was the same on both sides, so I knew the suspension was level. what I found to be the problem was my right side bumper support bolts were loose, causing the right side of the nose to sag. I jacked to nose up to the correct height, and torqued the bumper support bolts down. problem solved.
Old Apr 4, 2013 | 06:22 AM
Danish Shark's Avatar
Danish Shark
That looks silly.
It completely ruines the profile of the car.
Old Apr 4, 2013 | 07:18 AM
scottw's Avatar
scottw
To me, it is too low. I wouldn't have cut the springs. BUT, If you like it and it rides good, then NO, it's not too low. Get out there and enjoy the spring.
To Too Low?
Old Apr 4, 2013 | 08:01 AM
diehrd's Avatar
diehrd
I think it is to low, it looks like it has bad springs up front ..
Old Apr 4, 2013 | 09:53 AM
7t9l82's Avatar
7t9l82
its not supposed to look like a four wheel drive either. with a a more modern wheel and tire package it would look killer.
Old Apr 4, 2013 | 10:12 AM
Garys 68's Avatar
Garys 68
When you run out of shims on the front suspension, it's too low.
Mine had a coil cut up front before I got it. Largert radiator, added Vintage Air, a 6 speed Richmond brought it down a little more. Longer rear bolts evened it up. Looks about the same as mine.
