Electrical Ground Points
Poking around the window motor with my multimeter just confirmed it.Yesterday I washed the car, and after starting the car, EVERYTHING WORKED AGAIN
!! All the dials worked, the tach, the windows, everything- til the car dried off.
If someone could point me to where all of the electrical ground points on the car are, that would really help me! I searched through the mitchell and chilton manuals to no avail. Pictures would be awesome, or even just a description of where the ground points physically are and how to get to them. Any tips on checking and fixing grounds would be greatly appreciated.
The first pic. shows the ground from the engine to the frame.The black wire in the second pic. is for the starter wiring and is attached to the bell housing to motor bolt. The third pic. shows the ground on the back of the alternator. The negative cable from the battery is attached to the frame but I can not find a pic. at this time. There are many more throughout the car.
Bill beat me. Bill, did I ever tell you that you are Weird?
Dont know about 76 or 74 but my 69 has or had ground wires at the number 1 body mount from the rocker channel down to the frame / body mount. Could explain while wet some stuff worked as it may have gotten wet. Then like above youve got grounds that go to the birdcage behind the dash that need to carry over to your tach and center console.
One on the rear drivers side frame for the antenna.
Drivers side #2 body mount uses a copper strap clip on style. May be on the opposite side too, I don't recall.
Radiator frame. Drivers side, one or two black wires from harness.
Metal support across the front for the headlights.
From the battery compartment just to the drivers side of the rear crossmember /snubber differential connection/emergency brake line bracket.
Inside birdcage/drivers side just above #2 mount
Cross bracket underneath shifter
there may have been one under the dash are towards pass side.
Look for 7/16" holes ( motor mount & Battery ground ) and smaller 5/16" (?) taillights, gas tank, antenna
Photo download not working on this GD forum. I'll try and post later.
