Good Clutch?
Old Apr 5, 2013 | 10:55 AM
stingrays_r_us's Avatar
stingrays_r_us
Default Good Clutch?
I am about to convert my 72 from auto to manual. I have a freshly rebuilt M20 wide ratio that I'm going to install. I have a stock 200HP 350 NOM. I do plan on cam, and top end kit at some point to wake the car up some.
Any recommendations for a good clutch assembly? In my old 73 I used a Perfection clutch from the local Advancedauto, but it seemed to be "sluggish" even on a stock motor.
Old Apr 5, 2013 | 12:41 PM
MelWff's Avatar
MelWff
why dont you try www.summitracing.com put in year/make/model search within results for clutch kits and what usage the car will see.
Old Apr 5, 2013 | 01:56 PM
Mako72's Avatar
Mako72
2018 C3 of Year Finalist
After vibration issues with a Centerforce Dual Friction, I switched to a McLeod. Holds great and easy pedal.
Old Apr 5, 2013 | 03:19 PM
dochorsepower's Avatar
dochorsepower
It's hard to beat a GM 11" clutch.
Old Apr 5, 2013 | 03:30 PM
qwank's Avatar
qwank
I used a stock 11" replacement clutch from NAPA and it works great
Old Apr 5, 2013 | 07:52 PM
BB68Vett's Avatar
BB68Vett
I have a Centerforce Dual Friction behind my big block for 10 years. Still works good.
Old Apr 5, 2013 | 08:00 PM
gcusmano74's Avatar
gcusmano74
On a street car, use a "street" clutch. A racing type clutch will not operate as smoothly, and the pedal effort will likely be higher as well.
Old Apr 5, 2013 | 08:28 PM
flyeri's Avatar
flyeri
I used the Centerforce DF because I needed the clamping force behind my big block, BUT I wanted a street clutch feel so the wife would be comfortable on the occasions she wants to drive. I've not been disappointed with its performance. I don't really consider it a racing clutch if that is what gcusmano74 is referring to. The ceramic puck clutch I removed was a racing clutch. The Centerforce II is a good choice also. It uses the same pressure plate but a slightly less aggressive disk.
Old Apr 5, 2013 | 10:44 PM
73, Dark Blue 454's Avatar
73, Dark Blue 454
I too run CenterForce clutch kits. The DF (dual friction) I use is said to have 90% more grip than stock. And the pedal is as light as new Nissan or something.
Old Apr 6, 2013 | 12:29 AM
gve's Avatar
gve
I had the centerforce and always had some vibration, pulled the transmission out you could see the weights that sling out at higher RPMs were not centered. I removed the weights and now its smooth as silk, I would not buy centerforce.
Old Apr 6, 2013 | 12:55 AM
l88rocket's Avatar
l88rocket
I like the Centerforce DFX line, Ram makes a good clutch also
Old Apr 6, 2013 | 03:11 AM
harris1507's Avatar
harris1507
No problems with mine either (Old Car), I would buy one again for my new car
Old Apr 6, 2013 | 09:59 AM
SuperBuickGuy's Avatar
SuperBuickGuy
with 300 hp, you don't need an exotic clutch. RAM, McLoed, Centerforce.... any name brand, actually, would work just fine.
Old Apr 6, 2013 | 10:30 AM
1974ta's Avatar
1974ta
Default Clutch
LUK is OEM GM manufacturer.
Seem to be priced right with excellent reviews.
Bill
Old Apr 6, 2013 | 04:10 PM
glen242's Avatar
glen242
I have been running a CF II for several years, without problems, on my 383 stroker. I would estimate flywheel HP and torque in the 400 range. Gotta get it on a chassis dyno this year.
It is a strictly street driven car. I do, on occasion, do hard launches without any problems. I researched the CF line before I purchased, and the CF II seemed the way to go.
I wonder how many people really need a CF Dual friction clutch, based upon what they actually have for an engine, or is it just bragging rights or every weekend racing?
Curious as to what the CF Dual people have for engines. Dyno results are needed to evaluate your combination along with vehicle usage, drag racing, etc. I will not speculate on my actual HP and torque until after a dyno test.
My modifications are in my profile. Using those specs, is how I came up with my WAG number of 400 range of engine HP and torque.
Feel free to disagree/dispute my WAG numbers while you supply your own WAG numbers.
Old Apr 7, 2013 | 03:40 PM
pricesgarage's Avatar
pricesgarage
centerforce df is a good cutch for a crusier or mild racing they do not like burn out contest or 6500 rpm clutch dups on slicks but there great on normal driving
Old Apr 7, 2013 | 05:38 PM
drwet's Avatar
drwet
I have a couple of Centerforce clutches. They perform well and the pedal feel is just like stock. I don't really beat on them though. Just some spirited street driving. fI've found the generic replacements are a crap shoot, so now I go with Centerforce every time I need a clutch because I can count on them to work the way they are supposed to.
To Good Clutch?
Old Apr 8, 2013 | 10:49 AM
lowes-yellow77's Avatar
lowes-yellow77
Default Luk
Bill
LUK clutch is great they wont handle to many 5000 rpm clutch dumps but grab tight when you need it to with manual linkage my pedal is a bit stiff so if you want something easier just swap over to a hydraulic clutch setup
Old Apr 10, 2013 | 10:05 AM
stingrays_r_us
Thanks for all the input
I went ahead and went with the NAPA clutch and flywheel. I have always had success with their starters, alternators etc. unlike the cheap stuff from Advanced/autozone, and if something is wrong I can put my hands on somebody close by
Old Apr 10, 2013 | 12:16 PM
drwet's Avatar
drwet
Unfortunately if something is wrong with it, you're the one that gets to pull the transmission and bellhousing again.
