1970 Vacuum question
Old Apr 7, 2013 | 11:32 PM
vetteguy22's Avatar
vetteguy22
Default 1970 Vacuum question
Getting ready to remove the vacuum set up for my head lights and windshield wiper door due to low vacuum from the motor. Just curious, is there anything else the vacuum operates on the 1970? I believe that on my wife's 1982 it also operates some of the heater/air condoner controls. If not, then I can remove all the vacuum and not have to trace anything out. Thanks for any help.
Old Apr 8, 2013 | 12:38 AM
early shark's Avatar
early shark
How about the power brake booster.
Old Apr 8, 2013 | 12:50 AM
vetteguy22's Avatar
vetteguy22
I've gone to a hydro boost set up.
Old Apr 8, 2013 | 01:02 AM
calwldlife's Avatar
calwldlife
St. Jude Donor '22
Old Apr 8, 2013 | 01:12 AM
vetteguy22's Avatar
vetteguy22
Originally Posted by calwldlife
Does that mean there is no other vacuum operate items on the 1970?
Old Apr 8, 2013 | 01:22 AM
calwldlife's Avatar
calwldlife
St. Jude Donor '22
it means the climate control is run by vacuum like the 82.
they ll have the basic same system.
Old Apr 8, 2013 | 01:32 AM
vetteguy22's Avatar
vetteguy22
Ok, thanks. Hopefully I will have enough vacuum to run that.
Old Apr 8, 2013 | 05:36 AM
Danish Shark's Avatar
Danish Shark
Why not just add a vacuum pump instead?
Old Apr 8, 2013 | 08:11 AM
Belgian1979vette's Avatar
Belgian1979vette
I have done that and it's feasable but it's a bitch getting the leaks sealed.
Old Apr 8, 2013 | 08:13 AM
Alan 71's Avatar
Alan 71
Hi,
On 1970 cars there is a very small rubber vacuum line that runs off a 'tee' in the large vacuum supply line for the wiper door and passes through the firewall on it's way to the heater/defroster controller. Another line continues down the transmission tunnel, across the seat bulkhead on it's way to the controller for the astro vent doors
In 71 the tee is very near the right side hood latch... not sure just where it is in 70.
How are you going to operate your lights and wipers?
Regards,
Alan
Old Apr 8, 2013 | 08:55 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Do you have factory AC?
Old Apr 8, 2013 | 09:52 AM
vetteguy22's Avatar
vetteguy22
No air conditioning. I am using electric motors for the headlights (Mazda Miata) and am using a long L88 hood to eliminate the wiper door.
Old Apr 9, 2013 | 02:35 AM
Haggisbash's Avatar
Haggisbash
You say no air con but was it formerly an air con car? What about heater valve water control? Also vacuum operated door that directs air under the dash from heater.
Old Apr 9, 2013 | 07:42 AM
vetteguy22's Avatar
vetteguy22
No it was not a factory air car. That was my question, what all was controlled by vacuum. I guess I will leave the vacuum to the interior and see if I have enough to operate the climate control system. What are the guys doing that are using LS motors doing?
Old Apr 10, 2013 | 03:09 AM
Haggisbash's Avatar
Haggisbash
I have a 70 as well -
Wiper door
Headlights
Astro vent in back
Brake booster
Ignition advance
Heater controls - 3 vac units.
Old Apr 10, 2013 | 04:10 PM
vetteguy22's Avatar
vetteguy22
Thanks for the input guys.
Wiper door - Long L88 style hood
Headlights - electric (Miata motors)
Astro vent in back
Brake booster - hydro boost
Ignition advance mechanical only
So except for the climate controls, I guess I've got it covered. I will leave those in tack and see if I have enough vacuum to operate them.
Thanks again, I really appreciate it.
Old Apr 10, 2013 | 04:17 PM
aaroncorvette's Avatar
aaroncorvette
I'm doing a similar thing to you, I already have anL88 long hood installed and was about to do the electric headlight mod so thanks for asking a question I was going to ask
Old Apr 10, 2013 | 08:36 PM
vetteguy22's Avatar
vetteguy22
Are you doing it due to low motor vacuum also? if so what are you running for a motor?
To 1970 Vacuum question
