Door latch challenge for a 71
What type of work is "a lot of work"?
I think there are 2 different things being described here.
With the window down does the key lock and unlock the latch ?.... you should be able to feel that happening when turning the key.
What effect does the INSIDE **** have on locking and unlocking the latch when it's turned?
Remember the lock (lock and unlock the latch) and latch (release from the striker) are different motions in the latch.
Is it possible that the interior trim panel is somehow pushing on the locking/unlocking rods and preventing them from moving?
Regards,
Alan
The "a lot" means a frame off effort, but to a budget.
An aftermarket door panel was used - so that may be the cause. Will check this weekend.
Great picture of door mechanism.
