76 Stingray
Old Apr 9, 2013 | 12:53 PM
3vetts's Avatar
3vetts
Default 76 Stingray
My 76 Stingray, died and has no power what so ever. No lights, radio no electrical at all. Can not figure out why. Please Help. Was running fine got to stop sign and just died and has no electrical power at all. Put new ground cable and battery is good. HELP!!!!!!
Back up and running. See reply to "My 76 Ray" for the problem and fix. Thanks to all who responded with suggestions.
Old Apr 9, 2013 | 01:42 PM
billsfan's Avatar
billsfan
Could be a bad alternator. It crapped out, then the car ran on battery until the battery died. First, check battery voltage. Try jumping it, if still nothing, take the alternator to autozone or NAPA and have it tested. Next, look for grounds or other wiring issues. It's step by step, so start with the obvious and eliminate things one at a time.
Old Apr 9, 2013 | 03:56 PM
3vetts's Avatar
3vetts
Thought the same, battery is checking at 12.47 volts, and I did put a new ground wire. The only other place I am getting any power is at the starter and the alternator. No other power not even at the fuse box.
Old Apr 9, 2013 | 05:32 PM
my 76 ray's Avatar
my 76 ray
There is a fusible link down by the starter. It supplies current from the battery cable that is attached to the starter to the rest of the car. It should be a red wire attached to the same post as the positive battery cable. You can often feel that the wire inside the insulation is burned out.
Old Apr 9, 2013 | 07:47 PM
Jud Chapin's Avatar
Jud Chapin
St. Jude 15 Year Donor
St. Jude Donor '11 thru '25
Have u load tested the battery?
Old Apr 10, 2013 | 05:17 AM
palmbeachvette76's Avatar
palmbeachvette76
check voltage at the terminal on the starter to verify the positive cable is good then check the smaller wire past the fusible link and go from there.
Old Apr 12, 2013 | 11:50 AM
3vetts's Avatar
3vetts
Thanks for the help. I did go ahead and replace those fusible links because I could not tell for sure if they were bad. That did not fix the problem but it did point me in the right direction. I started tracing the wires from the starter and found a fusible link burnt at the connector that is on the fire wall. Got it replaced and power back on and car running. Thanks again.
To 76 Stingray
