C3 hot
Old Apr 9, 2013 | 10:56 PM
Dwayne Mcmillin's Avatar
Dwayne Mcmillin
7th Gear
Default C3 hot
I have a gen IV 454 bbc bord .060 over sealed power 10:25:1 pistons 427 crank shaft all mechined & balanced timing @ 10 degrees btc stage 3 cam intake cam lift .302 exh .302 high powered aluminum water pump offenhowser intake champion big block aluminum radiator will cool to 700 hp sealed power fel-pro gaskets kit part #260-1009 pro comp aluminum heads part#PC3021 at a idel 30 min 215 degrees driving 10 min 220 degrees i have coolent 50\50 1 gal mix 2 parts pure fide water & water wetter 7 blade fan high pro clutch what am i doing wronge help me please thank you in advance Dwayne Mcmillin e-mail dmcmillinn@aol.com
Old Apr 9, 2013 | 11:38 PM
speedreed8's Avatar
speedreed8
thermostat?, i put a stewart warner hi flo in mine, whats your timing set at.
Old Apr 10, 2013 | 12:36 AM
Dwayne Mcmillin
7th Gear
10 degrees btc I've tryed 4 tipes of thermostats & no thermostat 2 brass radiators & new alnminum bbc radiator cools up to 700 hp & sealed all around it took the tag plate off in front & sent up a prayer
Old Apr 10, 2013 | 01:21 AM
Les's Avatar
Les
Do you have a shroud for the fan? How's your primary jetting? Too lean can sure bring heat. Also, if your ignition curve is set to come in quickly that can play a role.
Old Apr 10, 2013 | 02:45 AM
Dwayne Mcmillin
7th Gear
yes i have a full shroud cam lift int..302 exh..302 valv lift int..513 exh. 513 lobe ctr int.105 exh.114 lash hot hyd int. & exh. sae duration 309 int. 309 exh. .050 duration 230 int. 230 exh. sae timing btc 42, abc 87,bbc 82, atc 47 .050 timing btc 9, abc 41, bbc 49, atc 1, carburetor 600 Edelbrock Performer 1405 ignition curve vac advance open all the way hooked to manifold port for full vac at idle & is working
Old Apr 10, 2013 | 05:13 AM
palmbeachvette76's Avatar
palmbeachvette76
What year is your car? this won't cure your heating which in theory really isn't too hot but I understand doesn't sit well with you but 600 cfm carb on a big block is too small. I would use a 750 and if your happy with the Edelbrock then stick with that brand. I tried their 750 (#1407) on mine for a weekend but it didn't agree with my setup so back in the box it went on the shelf where it sits today.
If your still running in the 200's at cruising speed I would look at the front end of the car and for the air dam/deflector that sits under the radiator, that makes a huge difference at directing air flow up and into the radiator at driving speeds.
Getting hot in traffic and at idle is the same problem I have with a small block and I've tried everything you listed and still haven't found the magic setup so I'll be interested in seeing what you come up with.
Good Luck,
Eric
Old Apr 10, 2013 | 05:59 AM
Danish Shark's Avatar
Danish Shark
10 btc is not much, for a BB 16 is usually possible (with the proper advance setup).
If you're able to bump it up a little that may help a bit on the heat issue?
Old Apr 10, 2013 | 08:49 AM
Dwayne Mcmillin
7th Gear
73 corvette whide open in the front radiator sealed all around had a 350 sb before with 40 year old brass radiator ran 185 degrees look at your radiator or timing chain thanks
Old Apr 10, 2013 | 08:51 AM
Dwayne Mcmillin
7th Gear
I will try i think it was tryed, 12,10 btc was thanks
Old Apr 10, 2013 | 11:24 AM
Les's Avatar
Les
I agree with PBV76 on the carb. First of all, your big block will run noticeably stronger with a 750 or 850. More importantly, that 600 is almost certainly designed for a small block and would be jetted accordingly. That could, of course, be dangerously lean for a performance big block like yours.
I've had a good look at a Quick Fuel carb recently and I like what I see. Here's a link to their line- http://www.quickfueltechnology.com/. I'd talk to them and see what they recommend for your engine- if you call them, have your specs ready because their tech guys have sounded like they really know what they're doing the 2 times I've talked to them. Other good options would be the Holley or Barry Grant performance lines.
The other big question is- when you went from a small block to the big block engine, did you stay with the small block radiator and support or did you upgrade to big block parts. There's a difference in capacity between the two and that's for good reason.
Old Apr 10, 2013 | 12:58 PM
Rebelrob's Avatar
Rebelrob
Dwayne, I got a hi perf BB. I have the initial timing set at 19 degrees with around 35 total. I use my vac advance connected to manifold vac. This will reduce your temp. I have a Dewitts Rad and Spal Fan set up. Stays right at 180*. I cannot speak for any other aftermarket rads.
Old Apr 10, 2013 | 01:24 PM
scrappy76's Avatar
scrappy76
Carb is too small for that engine and it might be effecting your temp.
What temp are you using for the thermostat ?
is the new radiator a 3 core or 4 core ?
Have you burped the cooling system completely yet ? I just put a new rad in mine and it took a little while to get all the air out.
If you continue to drive does the temp continue to go up past 220 ?
As your idling does it go past 215 ?
Old Apr 10, 2013 | 02:42 PM
Dwayne Mcmillin
7th Gear
I shut it down at 215 it got all most to 220 it looks like it will go higher if i let it set the timing at 16 btc seems to stay at 211 now drags at start up but it starts ok I have a new champion radiator for a bbc corvette cools up to 700 hp but has ownly 3 core rows cools better then the big brass I'm looking at 4 core now idling at 211 now still afraid to drive it thermostat is 180 back to the drawing board thanks all
Old Apr 10, 2013 | 02:46 PM
Bicyclewrench's Avatar
Bicyclewrench
Without seeing it I'd suspect that fan. The ones I've seen have smaller blades than a stock fan. I had one on an older car. It just didn't move enough air. I put the stock one back on and viola no worries.
Old Apr 10, 2013 | 03:37 PM
Dwayne Mcmillin
7th Gear
Rebelrob it's likes 19 btc stays at 210 under aload going to up grade the radiator to a aluminum 4 core row that should drop me a few more degrees in temp I'll be happy then thanks for all the help everone
Old Apr 10, 2013 | 06:40 PM
drwet's Avatar
drwet
You're not using punctuation.
To C3 hot
