simple question on courtesy light.
Old Apr 11, 2013 | 02:09 PM
commander_47's Avatar
commander_47
Default simple question on courtesy light.
81 model.
Where does the courtesy light under the drivers side dash attach?
Old Apr 11, 2013 | 02:15 PM
briankeery's Avatar
briankeery
If you get on your back and try to shimmy up under the steering wheel, you will see a slot molded into the bottom of the dash that the small clip on your courtesy light will clip into. This slot is pretty much directly below the steering column, about 2 inches in length.
Old Apr 11, 2013 | 05:21 PM
KapsSA's Avatar
KapsSA
Active Streak: 90 Days
http://forums.corvetteforum.com/c3-t...-it-mount.html
Old Apr 12, 2013 | 12:05 AM
vettezobsezzed's Avatar
vettezobsezzed
I just plugged mine in the other day.. Took off the plate by headlight vac switch, on my back found the slot and stuck it in
Old Apr 13, 2013 | 01:59 PM
commander_47
Thanks guys.
I'm spending the day doing stretching exercises to get my ample azz under the dash tomorrow.
To simple question on courtesy light.
