1981 will not accelerate when engine cold.
Old Apr 11, 2013 | 08:38 PM
dreamweaver1's Avatar
dreamweaver1
Default 1981 will not accelerate when engine cold.
My 1981 corvette will not accelerate when engine is cold. Have to gently pump accelerator to get it to go. Little to no response from pedal other than extreme hesitation and near stall. Runs great when warmed up.
Here's what I have done.
Rebuilt the Quadrajet
Replaced computer
Put new plugs wires rotor and cap on.
Replace intake manifold gasket.
Cleaned EGR valve.
Set timing to 6* BTDC
Dwell on 6 cylinder scale reads 28* and goes up to 35* with rpm increase.
Idle air bleed set to 5/32 "
New TPS
New MCS
Electric Choke sets with engine cold at 1/8" open and opens as choke heats up in about 2 minutes.
This is very annoying. Tired of sitting for 10 minutes waiting for engine to reach operating temp to drive.
Anyone have any more ideas?
Old Apr 11, 2013 | 08:42 PM
calwldlife's Avatar
calwldlife
St. Jude Donor '22
a lazy 02 sensor.
idle air bleed to 5/32?
you mean sol travel.
Old Apr 11, 2013 | 08:49 PM
dreamweaver1
Yes, Sol travel at 5/32. I replaced O2 sensor as well.
Old Apr 11, 2013 | 08:58 PM
calwldlife's Avatar
calwldlife
St. Jude Donor '22
2 things control it, 02 and coolant temp sensor.
Old Apr 11, 2013 | 09:01 PM
CaseyJones's Avatar
CaseyJones
St. Jude Donor '15-'16
Is the accelerator pump lever in he correct hole? Does it act lean at all after it warms up? Thinking about a cold-state vacuum leak somewhere. Is the rest of your vacuum system in good shape? Does it crank OK when the engine is warm? Thinking about a slipped balancer ring throwing the timing off a little. Float setting a little low? Choke pull-off working too quickly? Just taking stabs at a lot of possibilities...
Old Apr 11, 2013 | 09:30 PM
dreamweaver1
New coolant temp sensor, replaced headlight vacuum check valve and headlight actuator seals. Tested vacuum system with tester. All is good. Cranks fine hot or cold.
I'm thinking choke pull off working to quickly as well, creating a lean carb at cold operation because stepping on pedal I can feel response from accelerator pump action but no acceleration from fuel flow .
Once engine reaches operating temp it runs great.
Old Apr 11, 2013 | 09:38 PM
calwldlife's Avatar
calwldlife
St. Jude Donor '22
op temp?
could your thermostat be stuck open?
the temp sensor sends an ok at 150deg. 02 is warm by then.
I hear a definate rich to lean motor sound when those 2 sensors get to temp.
under 3 mins.
I have driven with bad 02 and coolant sensor, IE full rich and never had the issues you describe. but I don't beat on it.
not saying you are.
curious what sol number of turns you use and what
idle mix turns and air bleed turns.
Old Apr 13, 2013 | 07:04 PM
dreamweaver1
Problem solved. It was the M/C solenoid adjustment. Thought I had set it when I rebuilt the carb but did not. Adjustment was all the way in. Carb wasn't seeing full rich because metering rods were not raising up enough to allow rich fuel mix at cold operation.
Old Apr 13, 2013 | 07:14 PM
calwldlife's Avatar
calwldlife
St. Jude Donor '22
Old Apr 13, 2013 | 10:13 PM
7T1vette's Avatar
7T1vette
Just curious...
Why would you check 'dwell' on the "6 cylinder" scale???
To 1981 will not accelerate when engine cold.
