Upper control arm shafts
Old Apr 14, 2013 | 02:09 PM
manfroni's Avatar
manfroni
Default Upper control arm shafts
I'm in the process of rebuilding the front steering of my '78. My question is, the passenger side upper control arm shaft has 7/16" of shims and the drivers side has one very thin shim. Do I need offset shafts to eliminate some shin on the passenger side and invert the shaft to add some to the drivers side? The car had an alignment last summer, so it should be close. Thanks for the help.
Old Apr 14, 2013 | 03:35 PM
my 76 ray's Avatar
my 76 ray
As long as the car is able to be aligned properly, I wouldn't worry about the number of shims on each side.
Old Apr 14, 2013 | 03:39 PM
calwldlife's Avatar
calwldlife
St. Jude Donor '22
while I agree with ray76, I would wonder what is sagging or
out of balance.
if the car handles right and no obvious low side, I would keep an eye on it for future work.
Old Apr 14, 2013 | 05:13 PM
manfroni's Avatar
manfroni
The car handles and drive very well. The height is 29 inches on both sides exactly from the groin to the top of the wheel opening. I have had the car since new, and I can't remember what the shim configuration used to look like. What could be sagging?
Old Apr 14, 2013 | 05:20 PM
calwldlife's Avatar
calwldlife
St. Jude Donor '22
proper measure is under car at frame.
the A arms can be tweeked, crossmember sags.
don't worry until it can't be aligned or drives bad.
I understand your concern. sorry to worry you.
Old Apr 14, 2013 | 06:39 PM
DUB's Avatar
DUB
The "odds" that both sides of your upper control arm shim points are very unlikely. It does not matter...becsue then the alignment head are attached and measuered...the technician will be told what to do to make sure that your alignment is correct.
The "problem" that is inherent with the 63-82 Corvettes are that the engine cradle collapses over time. So the distance between your upper control arms begin to come closer to each other...due to bumps in the road, etc. In order to get the control arm to go back out as required....shims are removed to achieve this. When you have NO SHIMS in the upper attachment points. This is when either you have the cradle stretched back to its dimension (or at least to where you can install and have shims in place again so you will have years of alignment capabilities)....OF...you install an off-set upper control arm shaft...which will buy you some time...depending on how much you drive it and how bad the roads are in your area. The only semi-permanent fix is installing the cross-shaft and brackets that connect the upper control arms points together. And this cross-shaft kit DOES NOT allow you to spread the cradle back to original configuration...it just keeps if from keeping any worse.
DUB
To Upper control arm shafts
