What's everyone using for starters?
Old May 15, 2013 | 10:16 AM
Street Rat's Avatar
Street Rat
Default Latest update from OP
Went for a drive to the machine shop to check on my new motor yesterday. The outside temperature was 87 degrees. When I came out the car wouldn't start. I had to let it cool down before it would start again. This is the last time that I'm dealing with this crap. DEMON STARTER BE GONE!
I came home and ordered a Powermaster ministarter from Summit. I'll let you know how things go as the summer heat begins to climb.
Old May 15, 2013 | 12:21 PM
bluedawg's Avatar
bluedawg
Good luck, do you think that the starter is getting heat soaked?
Old May 15, 2013 | 12:24 PM
Street Rat's Avatar
Street Rat
I have no doubt. There is a header primary tube right next to it. This isn't the first time. Always when its warm outside.
Old May 15, 2013 | 12:30 PM
qwank's Avatar
qwank
The best part about the R motor starter is if you have headers, you don't need to remove the right one to replace the starter.
Old May 15, 2013 | 12:52 PM
bluedawg's Avatar
bluedawg
You think about either wrapping the header and pipe, or ceramic coating? When i had my first truck, it came with cheap headers and small leaks from the valve cover. It would eat a starter about every two months. Once i figured out that cheap valve covers were bent on the flange and wrwpped the header it seemed to cure the starter issue. Ive got ceramic coated headers on my vette, which run pretty close tto the starter with no issues. Its the original starter, or atleast original to me.
Old May 15, 2013 | 12:55 PM
Wrecked82's Avatar
Wrecked82
Had same problem on my 82 about a dozen years ago. Went through a starter each summer. Then got a Protorque mini starter from Summit Racing and wrapped it with a fiberglass heat shield. Never a problem since, 12 years later.
http://www.summitracing.com/search/p...orque-starters
Old May 15, 2013 | 12:59 PM
Street Rat's Avatar
Street Rat
I have ceramic coated headers and the factory heat shields on the starter. You are correct bluedawg. If I wrapped the header it would probably be a quick and inexpensive fix. This way the problem will be eliminated.
Old May 15, 2013 | 01:59 PM
C3 Stroker's Avatar
C3 Stroker
Powermaster XS Torque mini........no problems more than 15 years so far.
http://www.summitracing.com/parts/pw...model/corvette
Old May 15, 2013 | 11:51 PM
Dustup7T2's Avatar
Dustup7T2
Terrorizing Orange Cones
I'm gettin' so old that I can't lift those original 15 lb (?!) starters anymore and bought a lightweight mini. Problem solved.
Old May 16, 2013 | 07:57 AM
kwplot34's Avatar
kwplot34
Originally Posted by TimAT
I must be doing something wrong. Ol' Red still has the same starter GM installed in 69. (Actually Nov 68 per the build date). No heat shield, headers, and 12.5:1 compression. I did just have to replace the solenoid. The big contact in it got so nasty it wasn't making contact anymore.
You are doing something wrong Tim. you only start and drive your car twice a year you need to get that new motor built and drive that car.
Old May 16, 2013 | 08:44 AM
augiedoggy's Avatar
augiedoggy
Originally Posted by lionelhutz
Ya, you would want to put newer designed better engineered parts on your car.
Not everyone wants a better car.... the restoration guys usually don't. They buy a newer second car for that.
On a serious note,
I totally agree though... Its funny to see some of the same guys who see no issues with changing virtually everything else in their drive train for performance reasons talk about the old direct drive heavy amp robbing OEM starter like its the holy grail of ingenuity that shouldn't be touched and everything else is a "boy racer" toy..... sure oem starters can work but so can smog heads, We don't have debates about those being replaced?
I bought a mini starter off eBay myself after doing some research and finding the exact starter only a different color in the summit catalog for twice the price....
Old May 16, 2013 | 03:10 PM
mrvette's Avatar
mrvette
On a serious note,
Ed Zachary rite!!!! only I went local years ago, for my '89 350 truck roller block, years ago....I know it's a mini, but about offset bolts or such....no recollection....
