motors out..suggestions/performance?
Old Apr 20, 2013 | 10:56 PM
Little Mouse's Avatar
Little Mouse
Strait from edelbrocks own catalog, cam 2102 that comes in the 2022 power package. Cam 2102, 50 state legal combined with the 2701 manifold ( also in kit ) and there cylinder heads. Edelbrock says 320 hp with 389 lb ft of torque. cam has a whopping lol .420 intake valve lift with .204 at .050 intake duration. On top of this with the 2701 eps manifold its only square flange. You now need another carb, more money for a 320 hp engine. Yep that cam helps pass the california enviromentalist ****'s test but it will hold your engine way the hell back.
If you don't have the top end kit and you want edelbrock heads i would suggest you use the 2101 performer manifold that allows your q-jet if you want to retain your stock air cleaner and don't even consider that joke of a cam, look at lunati's vodoo series of cams.
But even if you want a new carb don't use that cam your just cutting your own throat with it.
Old Apr 29, 2013 | 03:35 AM
mwalt60's Avatar
mwalt60
Cruising
ok so here it is.
edelbrock e-street- 64cc heads
performer eps manifold
comp cams 462-469 218* 224*
comp cams high energy rocker arms
performer 600 carb
water pump, fuel pump aluminum radiator and all that will follow.
should I use a 2000 stall, thats what comp cams recommended.
Old Apr 29, 2013 | 03:37 AM
mwalt60's Avatar
mwalt60
Cruising
yes I have installed cams before, but the motor is going to the engine shop tomorrow to get a long time in the hot tank lol its soo bad. so they are going to do new seals, rering, freeze plugs and balance for 900$
Old Apr 29, 2013 | 09:42 AM
cv67's Avatar
cv67
St. Jude Donor '05
Those parts should play real well together
2000 stall will work a 24-2500 would wake it up and drive like stock still manner wise. Little funner when you hit the pedal on the right too.
Is that the old high energy cam or the XE?
Old Apr 29, 2013 | 11:01 AM
Little Mouse
on the 2500, ajthrom that has a lot of experience with stall converters will also tell you of the more reasonably priced converters the hughes brand, summit sells them. Most people seem to buy a 1406 edelbrock 600 without paying attention its an economy carb nice way of saying jetted more lean non performance. Glad to see the edelbrock cam went out the picture.
Old Apr 29, 2013 | 09:13 PM
Little Mouse
The only difference in the... calibrated for fuel economy... 600 is the .098 primary jet the manual choke 1405... calibrated for performance... uses a .100 primary jet. The only real mistake you were going to do originally was using that miserable edlebrock cam. You could use an inexpensive 670 avenger or the edelbrock carb.
I would have sent the Q- jet to lars let him do his magic on it but you are using a square flange manifold and seem to want a new carb. Of the two new carbs i would do the avenger but maybe im biased torward holley.
Old May 19, 2013 | 10:18 PM
mwalt60's Avatar
mwalt60
Cruising
So here's the final list. Motor will be done this week and then Also l how I did lol.
Block bored .30 over
Flat top pistons
Arp rod and main bolts all bolts actually will be arp
Edelbrock estreet 64cc heads
Comp cam 462. 469.
Steel roller rockers
Fluidampr
Edelbrock fuel pump
Hughes 2500 stall
aluminum radiator with dual 12" electric fans
Stant 175 stat
Billet specialties goodies
Possibly march vbelt or serpentine pulley kit
As far as carbs im not sure yet. Either 600 performer or avs 650 with electric choke
And im not sure about a new distributor or just keep the delco.
Also what about different plugs or wires or just buy new plugs same as origional. I didnt know if i ahould run something hotter since i will be around 10:1 compression
Old Sep 10, 2013 | 05:00 PM
mwalt60's Avatar
mwalt60
Cruising
heres a pic of where im at right now. just waiting on belts and some vacuum line and I need to finish some wiring for the fan control.
mwalt60's Avatar
mwalt60
Cruising
Old Sep 11, 2013 | 04:31 AM
uxojerry's Avatar
uxojerry
Looks fantastic!
Old Sep 11, 2013 | 02:23 PM
91turbo2's Avatar
91turbo2
Very nice.
Old Sep 11, 2013 | 06:20 PM
bluedawg's Avatar
bluedawg
Looking nice!
Old Sep 13, 2013 | 12:05 AM
  #33
garygnu's Avatar
garygnu
looks great !try to mount your tranny cooler 1" away from the radiator .
