Is this all somehow connected?
Old Apr 17, 2013 | 03:05 PM
Linas's Avatar
Linas
Default Is this all somehow connected?
1973 454 automatic with bigger cam (not exactly sure about the specs). Headlights are going up/down quite slow. Engine does not idle properly, there is always a need to keep it revving a bit, otherwise it dies. Also it is very difficult to engage reverse gear, especially if the car is sitting on incline surface.
Is this all caused by insufficient vacuum? Eg. not enough vacuum for quick operation of headlights, not enough vacuum for distributor vacuum advance. I assume, I could try switching distributor advance vacuum from port in the carb to port in the manifold? But what about the gearbox, is this problem related to vacuum?
Any hints would be very much appreciated
Old Apr 17, 2013 | 03:14 PM
CaseyJones's Avatar
CaseyJones
St. Jude Donor '15-'16
The cam could very easily cause all sorts of vacuum issues, but I would be sure to check all the system for leaks, too. That could also worsen a weak vacuum condition. The transmission problem is not vacuum related. I'd be sure to check the fluid and possibly service the transmission (new filter and fluid) before going much further. That is assuming it is not a mechanical problem. The shifter to transmission cable may need attention. So much to check.
Old Apr 17, 2013 | 03:17 PM
Oldguard 7's Avatar
Oldguard 7
It would be good to know the specs of the cam. A cam too large could affect the headlamp operation. More importantly, the brakes. How do the brakes perform? Does the transmisson shift smoothly. Is the vacuum modulator operating properly? Have you have any loose, missing vacuum lines? Let us know.
Old Apr 17, 2013 | 03:44 PM
oldschoolvette's Avatar
oldschoolvette
did this start at the same time the cam went in?
was it like this when you got it?
need to understand the relationship of the cam install and the start of the problem
Old Apr 18, 2013 | 12:42 AM
Linas's Avatar
Linas
Can't tell, whether it started after cam install. I got the car the way it is.
Ok, so it looks like there is no connection between not going into reverse and idle/headlights.
Old Apr 18, 2013 | 10:05 AM
lionelhutz's Avatar
lionelhutz
It sounds like you need to inspect everything for leaks and then do some tuning on it. Then see how it works when the timing and carb setup are optimized.
Do you mean it's hard to engage reverse because it stalls?
Old Apr 18, 2013 | 11:02 AM
Linas's Avatar
Linas
Nope, it is hard to engage reverse, because it simply does not engage Noticed, that the fluid level in my transmission is low-ish. I'll top it up and see what happens.
Old Apr 18, 2013 | 12:30 PM
lionelhutz's Avatar
lionelhutz
The reverse is a separate issue then.
Old Apr 19, 2013 | 04:00 PM
Linas's Avatar
Linas
I topped up the transmission with fluid and then closely inspected transmission vacuum modulator line. The rubber bit at intake manifold end was rough and I suppose it was leaking. So I replaced it and also switched distributor advance from ported vacuum at carb to manifold vacuum. Now engine idles much better and engages into reverse (with a second of delay). So afterall it looks like my transmission issue was vacuum related. Not sure, why some were so sure that there is no relation between vacuum and transmission?
Old Apr 19, 2013 | 05:08 PM
Bagmup's Avatar
Bagmup
The modulator has nothing to do with no reverse gear engaging, thats why. Your low fluid level would have been the cause.
Old Apr 19, 2013 | 06:53 PM
lionelhutz's Avatar
lionelhutz
Old Apr 20, 2013 | 01:10 AM
Linas's Avatar
Linas
Ok, thanks!
To Is this all somehow connected?
