busting up
Old Apr 18, 2013 | 01:00 PM
1977L48's Avatar
1977L48
Default busting up
so i just took my vette out for a cruise and things got bad, i went to get on it and it had little power and sounded like it was missing untill 3500RPM then it started pulling strong. all i did from yesterday was i put the strongest springs back in my dizzy due to unstable idle with new cam and replaced the R45TS with a set of R44t plugs. any help would be greatful!
Old Apr 18, 2013 | 01:05 PM
calwldlife's Avatar
calwldlife
St. Jude Donor '22
plugs are colder and will misfire until...
the more load the more misfire.
did you crack a wire or two when working?
use an ohms meter
springs? did you test them with a timing light?
a combo of the changes or one issue.
time to test.
Old Apr 18, 2013 | 01:08 PM
1977L48's Avatar
1977L48
one wire is alittle burned on the boot due to the old R45TS plug being longer than then R44T. and how do you test the springs with a timing light? just see what RPM they give full advance at?
Old Apr 18, 2013 | 01:17 PM
calwldlife's Avatar
calwldlife
St. Jude Donor '22
search for the "lars" info on dist.
I don't know what you were after in the changes made.
ignition gets funny when running out of specs.
the issue you experienced was misfiring under load break down.
wires will do that.
plugs will do that.
advance will contribuite to load.
so, everything done is suspect.
look up "testing ignition wires".
the heat range is curious. did the plugs show signs of heat?
good luck and you will learn.
Old Apr 18, 2013 | 01:19 PM
1977L48's Avatar
1977L48
years ago i was told that a colder plug was better in the summer for performance and run what was called for stock in the winter. but wouldent it cause it to bust up throught out the entire RPM range, not just till 3500RPM?
Old Apr 18, 2013 | 01:26 PM
calwldlife's Avatar
calwldlife
St. Jude Donor '22
ok, throw in a chance of a bad HEI ignition module.
does not explain the springs in the dist.
Old Apr 18, 2013 | 01:27 PM
MelWff's Avatar
MelWff
You went from a warmer extended tip plug to a colder non-extended tip plug. The R45TS was the correct plug the R44T is the wrong plug.
Old Apr 18, 2013 | 01:29 PM
calwldlife's Avatar
calwldlife
St. Jude Donor '22
heat ranges have to do with use.
freeway only, colder
stop and go hotter.
and previous poster nailed it.
Old Apr 18, 2013 | 01:34 PM
1977L48's Avatar
1977L48
Ok, so would a R45T be the correct heat range with a shorter overall length to save the new plug wires i got?
Old Apr 18, 2013 | 01:37 PM
1977L48's Avatar
1977L48
i went to the heavy springs because with the new cam i installed it had an unstable idle while in gear, timing is set at 10degrees and 36total timing
Old Apr 18, 2013 | 01:42 PM
MelWff's Avatar
MelWff
Default wrong plug
The R45T is NOT an extended tip plug. You need R45TS and I cannt imagine there is a sufficient difference in the length of the plug body to effect spark plug wires.
Old Apr 18, 2013 | 01:44 PM
MelWff's Avatar
MelWff
Default Unstable idle
Are you running manifold vacuum to the distributor vaccuum advance or ported vacuum. You should be running manifold vacuum to stabilize the idle. What springs are you referring to, were they part of a kit?
Old Apr 18, 2013 | 01:51 PM
1977L48's Avatar
1977L48
I am running the advance from a constant from the carb, i tested the readings with a gauge. And the springs were from the mr. Gasket curve kit
Old Apr 18, 2013 | 02:54 PM
1977L48's Avatar
1977L48
Ok, i fixed it, new R45TS plugs, new wires, put the lightest springs back in, to set timing i had a buddy sit in my car, put it in Drive and unhooked the advance, the load on the engine kept the idle stable to where i could time it, no backfire, great WOT performance, thanks everyone for the input
Old Apr 18, 2013 | 03:34 PM
MelWff's Avatar
MelWff
great to hear you fixed it!
To busting up
