Differential swap?
Old Apr 18, 2013 | 03:35 PM
tjlawson1's Avatar
tjlawson1
Default Differential swap?
I have a 1978 corvette and I want to change up the rear differential i hopes of being quicker off the line? I found a rebuilt one and it is off of a 63-early 70's corvette that had a BBC. Will this make any difference in my 78'? and if so, can i just "bolt it on" without any other mods? thanks for the help!!!
Old Apr 18, 2013 | 03:42 PM
MelWff's Avatar
MelWff
Without you stating what the current ratio is and what the ratio is in the rebuilt how can anyone tell you how much of a difference it will make. From 63 to 79 they are interchangeable.
Old Apr 18, 2013 | 03:53 PM
iokepakai's Avatar
iokepakai
Swap in an OD trans,best of both. 1st gear for start off's and OD for cruising on the hiway.Pick a trans that will complement your current rear gear for a 10:1 overall 1st gear.Example my rear gear is 3.08 times my 3.28 Richmond 1st gear gives a 10.1 overall start off ratio which is considered ideal.My .76 OD 6th gear gives me great mileage on the hiway.Makes for fun driving! Best upgrade on the vette for sure.
Old Apr 18, 2013 | 04:07 PM
tjlawson1's Avatar
tjlawson1
here is what the ad says about the diff,
Stamped AWW 2 70 E 1. which is a 3.08:1 Eaton positraction. Rear cover and threaded holes are in good condition. Housing denotes that it is a heavy duty rear differential out of a big block car.
and my car also has the 3.08:1, I just want to know if i will notice a difference with a rebuilt one? or what would you recommend for a rear end? I am putting in a rebuilt 350 and a rebuilt trans. I am new to this so sorry for the lack of info and knowledge on my part!
Old Apr 18, 2013 | 04:42 PM
MelWff's Avatar
MelWff
It's the exact same ratio so makes no difference at all. The ratio that would be a perfect middle between performance and economy would be a 3:55. As the other post suggested you can go to a OD transmission as an alternative. At the very least pump out the old fluid put in a bottle of additive and refill.
Old Apr 18, 2013 | 04:50 PM
tjlawson1's Avatar
tjlawson1
Thank you for the help!! I will look into an OD tranny!
Old Apr 18, 2013 | 11:37 PM
jackwabbit703's Avatar
jackwabbit703
Get a 4.11 gears like I did.. You will have love and hate relationship with your car. Just kidding.. 3.55 will be fine and if you're looking into OD, I would go with 4.11 gears with OD and have best of the both worlds...
Old Apr 18, 2013 | 11:42 PM
qwank's Avatar
qwank
3.08 is perfect for a Richmond Transmission
Old Apr 19, 2013 | 07:38 AM
71scgc's Avatar
71scgc
If that diff has been rebuilt, who knows what the ratio is. Go look at it, and spin it and count it out.
Get a 3.73 diff. Best street gear there is.
Carter
Old Apr 19, 2013 | 08:44 AM
diehrd's Avatar
diehrd
Your 3.08 will hate an O/D , the car may bog and stutter around like a wounded horse ..
Old Apr 19, 2013 | 09:46 AM
1977L48's Avatar
1977L48
and if you do swap in a 700R4 for the OD, its a very ease swap, need only a shorter drive shaft, shifter if you want to take advantage of holding 1st gear, and a lock up kit, painless wireing sells one, i got mine off jegs when i put a 700r4 in another car of mine, nice kit. very plug and play
To Differential swap?
