please help with cam selection
Old Apr 28, 2013 | 04:45 PM
augiedoggy's Avatar
augiedoggy
Originally Posted by Tim H
1: If a person can't afford a hotrod then they made a mistake buying or building one in the first place.
2:Just because a car has a loud exhaust and a lopey can doesn't mean its junk and has to be worked on all the time.
3: If I can't have what I want then I would rather do without instead of settling for something less.
4: I build an engine around the cam.
Your either intentionally trying to misinterpret what I'm saying or you don't understand that a thumpr can in designed to fake the idle of a real extreme "hot rod" cam while at the same time not giving even the performance level of other mild cams in its range...Half of your points are agreeing with what I'm saying?
The Thumpr a compromised design to give an excessive lopy idle at the cost of all aspects of performance.... performance is performance and a "hot rod" it supposed to perform not just look like a fast car that performs worse than stock...
That's like having the option of a roller cam or a flat tappet at the same cost... the smart person would choose the roller cam for all the performance gains.... if my mild 268h can provides better torque and HP as well as better gas mileage at the cost of not faking the cool idle of a much bigger can than so be it.... like was posted earlier I can always remove a plug wire and pose the same sound.
Old Apr 28, 2013 | 05:33 PM
bluedawg's Avatar
bluedawg
Originally Posted by augiedoggy
Thats what I told myself when I bought a lifted ram with a 5.9 and 4.56 gears and 35"mudders...... 5 years later and I put about 6,000 miles on it....instead driving the company toyota or one of my other vehicles like my vw kit car...
Bottom line no matter how much you try to convince yourself otherwise the gas mileage DOES come into play when it comes to how much you do or dont drive the thing unless your loaded.... I'm not saying its a deal breaker but when you have the choice of a better running more powerful car with good vacuum and brakes or a cool sounding car that "fakes" the sound of a much bigger race cam at the cost of power driveability, braking power and gas mileage well.... Just google it and read up on all the people on other forums who used them and recommend against them because of issues or removed them for a better cam....they are a bitch to tune as well from what I've been told.
If you want to be the guy at the carshow with all the people who know nothing about cars loving it and all the people that do giving you the same look I get when riding by harley guys on my metric cruiser or taking my kitcar to a carshow then do it... but just keep it in mind that most "gear heads" think of the thumpr cams as the epitome of a fake "poser" Part. Obviously having the other toys I have and a lifted truck with "compensating" across the windshield I dont really care what others think and I like the sound of the thumpr cam myself and if it hadnt been for the other performance compromises I would have used it in my vette but I just cant justify it on sound itself.... its like the reverse flow mufflers in the sidepipes bolted to a built up engine choking the output out...
I agree. Cnc motor sports built a 383 using the thumper cam and it put out 450 or so horse. I personally used a cam built for performance and let the sound happen to be what it is. When you look at the lack of power, drivability, vacuum & mileage you get from a cam built for sound, it don't make sense. Going with a performance cam and building the to use that Size cam and tunnel ram you'd actually get performance out of the deal as well as sound. As for mileage, we only get About 4.5 months of summer up here. Out of that were lucky if half is dry let alone sunny. About one in 6 summers is good summer. Considering I'm at work for two weeks outa every month then I don't get to drive my vette enough to be concerned with mileage. I did manage to put 2500 miles on one summer.
Old Apr 28, 2013 | 05:51 PM
Tim H's Avatar
Tim H
You do that and crack down on the gas for awhile and when the cylinder has had enough gas it will bend a rod.
I understand exactly what the thumper does, I don't race so I want the baddest sounding car that pulls into the cruise in or car show.
Old Apr 28, 2013 | 07:19 PM
bluedawg's Avatar
bluedawg
Tim even though you dont race, I'd bet your vette is no slouch. Don't you have a 11 sec nova to? I'd also care to guess that you don't run the thumper series cam. When I built up the l48 I used the xe262h all though the sound wasn't radical you could tell it wasn't stock. The xe288hr in my 400 has that distinctive sound that the mimic cams produce and still has power. Its been a while since I've looked at cams let alone the mother thumper, iirc you'd need about the same compression, stall and gears fort the motha thumper that you'd need to run a decent cam designed for power instead of sound giving that lopey cam sound. The spark plug remark was being a wiseass on my part and no I don't recommend anyone do that. But honestly if it was your vette being discussed what would you do?
Old Apr 28, 2013 | 08:03 PM
Tim H's Avatar
Tim H
They didn't make the Thumper cam back then, my favorites are the magnum series I have ran all of them.
The guy says he doesn't care about gas mileage, or performance just sound.
The thumper is made just for that train of thought, actually the only cam that states its a cam for loping, so if it was recommended to me I would say thank you and go to the web site and start looking at specs.
Also my current and last vette, if I keep it long enough already has a notebook started on it about yanking the previously installed cam by someone else and stab in the lopiest of the thumper series and a nice set of 202/160 heads!
Old Apr 28, 2013 | 08:30 PM
augiedoggy's Avatar
augiedoggy
Well I'll say it again.... I have a new thumpr 12-600-4 I believe for sale cheap!... but you'll need a vacuum booster for the power brakes and vacuum operated accessories to work so I've been told.... how true that is I dunno. Anything bigger than the thumpr I have required a higher than 2000 rpm converter...
